Prop Pro Dev Board burnout - Capacitor C1 replacement
Hi All,
Want to know how do you check the voltage on a cheap power supply? Plug it onto you PPDB and look for smoke...
Yeah that was me. I didn't test the P/S on my meter first so.... Pffffvvvtt. The good news is the board/prop/chips/etc are fine. The bad is I need to replace a capacitor. (Actually not all that bad!) This a cap C1, a 10uF on the PPDB schematics.
My question - What type of cap should I use to replace? Polarized? Ceramic? What tolerance, etc
I know I could slap any 10uF in place and be fine, but I am glad this particular one blew and warned me through smoke signals, so a similar/identical replacement is a good thing.
Thanks!
Paul
Yeah that was me. I didn't test the P/S on my meter first so.... Pffffvvvtt. The good news is the board/prop/chips/etc are fine. The bad is I need to replace a capacitor. (Actually not all that bad!) This a cap C1, a 10uF on the PPDB schematics.My question - What type of cap should I use to replace? Polarized? Ceramic? What tolerance, etc
Thanks!
Paul
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Once, I did use the right volts , just a bit backwards though, Prop survived, bless
