Serial to WiFi Module
Bill Chennault
All--
I have RC Buster up and running wirelessly via Bluetooth. I found out that Bluetooth does not like 9000lb. rocks. Whenever I let RC Buster loose out in the back yard and a big rock gets between him and my USB WiFi Class I dongle, I usually lose communications. I might try Parallaxs 433MHz stuff.
What I would like to know is if the WIZ610wi-EVB might fill the WiFi need on RC Buster. In my lay way of thinking, if I stuck the WIZ610wi on the 'bot, figured out a way to give it some power,·and interfaced it to the SX48, then I could talk to it . . . somehow. (I haven't got that figured out. If you do, I would love to hear about it.)
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
2.4GHz Bluetooth signals do not penetrate rock; You could try placing the USB Bluetooth dongle at a higher location (on the end of a USB extension cable) for improved coverage ?
regards
devidebyzero
G
We live in a walkout. Currently, the laptop from which I am running RC Buster is on the lower floor and highly subject to those big rocks lining my patio. Soon, I will move it to the upper level and rocks should not be a problem . . . other than the ones in my head.
--Bill
Thomas Talbot, MD
Gunpowder, MD, USA
I have no experience with XBee, although I know they are popular. Thank you for the suggestion . . . I will keep it on my list of things to try when I finally convince myself WiFi is not a viable option!
--Bill
I would drop the Blue tooth and go with WIFI.
WIFI has the range You need.
_______$WMc%____________
The Truth is out there············································ BoogerWoods, FL. USA
rs_jim
10x more power = 10x more range
____________$WMc%____
http://bluetoothinsight.blogspot.com/2008/01/bluetooth-power-classes.html
http://en.wikipedia.org/wiki/Bluetooth
Robert
I have a Class I dongle with an antenna. I do not know if the eb501 is Class I or Class II. Do you?
I am not complaining too much about the range I get from this setup. Other than failing to punch through solid rock, my Bluetooth setup pretty much covers my property and I have yet to bring the "base station" to the upper level of my walkout.
I just wish there were a WiFi equivalent of the Bluetooth serial cable replacement made possible by the A7 software. (Maybe there is and I just need to keep spending money until I find it.)
--Bill
Robert
Yes, my eb501 has an antenna that cost me extra.
I am not really complaining about Bluetooth and the eb501; the serial cable replacement mode·is neat and the range is fine for my CURRENT needs which are just to teach me a bit about a form of remote control. However, "down the pike" it will have to be replaced.
Ugha had a great suggestion for me: Instead of struggling to made the Logitech game pad work or striving to use my mouse-driven VB GUI, why not simply create a keyboard interface? It is so obvious it hurts. These young people!!! What will they think of next? [noparse]:)[/noparse]
--Bill
What I ment by "Cell Sites" was the concept of using 2 or more bluetooth tranceivers linked to the laptop with cat 5.· These two devices would each be paired with buster and set at angles such that if buster is in the rock shadow of one it could see the other.·I believe the bluetooth·on buster can be programed to automaticlly connect to paired devices when it looses communication with one it would connect to the next device it can find. ·Each Cell could be on an sx28 with RS485 or you could even go Eather net if you were so inclined.· RS485 would allow you to daisy-chain devices on a single cable back to central control.· The "Sattelite" idea was·an SX-28 with bluetooth linked back to control·via cat 5 and the "flown" over the back·yard with a fence to fence wire, balloon etc.
rs_jim
I get it. What a neat idea! I am going to save it and try it if my next neat idea does not do what I want.
However, the next idea is so neat (stupid?) that I don't think I am going to say a lot about it before I do it! [noparse]:)[/noparse]
--Bill
