EEprom pins
If I wanted to add a secondary eeprom ( non-booting of course ) will it operate the same on say pins 26/27 for standard read/write functionality??
K.
New ICON coming, gotta wait for the INK to heal, now we have colour!
K.
Yes, but you must make sure to address it differently with the A0,A1,A2 pins. If you address it the same as the boot eeprom, it will cause problems.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Just use Mike's I2C driver from the obex and change the pins for accessing the device.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Ha, I guess I should read the post more thoroughly next time. I swore the post stated the same pins as the boot eeprom, which can be done as well.
Anywho, the function works the same, but you will need the address you supply the eeprom with, and of course change the driver to access the eeprom with the correct pins.
edit- if you are trying to save I/O using the same pins as the boot eeprom is the best way. You just need to make sure to address the correct eeprom when accessing the secondary one.
James L
James L
Partner/Designer
Post Edited (James Long) : 5/6/2009 6:25:27 PM GMT
--Steve
lol
--Steve
No problem. I appreciate the fact you corrected me. I should pay a little more attention to the post, where I do not confuse the OP.
It was a simple mistake, and no offense was taken.
James L
James L
Partner/Designer
Mike's comments are so verbose they border on being long winded [noparse]:)[/noparse]
--Steve
