one engine, tank treads??
I've got a 3Hp Briggs and Stratton engine, and I wanted to make a mini tank of it, but obviously with one driveshaft, I can't control two sides. I was wondering if there was a way around this. possibly some kind of separate clutches or something?
MIKE
MIKE
I think the article was in Popular Science or Popular Mechanics, but am not sure. For sure it was a long time ago.
There's also hydraulic like the Quad Rover, or Hybrid like it's predecessor.
Rich H
http://hydraulics.eaton.com/products/trans_main.htm
-dan
If you want this project to be inexpensive, one possibility as well is to use a belt and pulley system, with treads turning when the belt is tightened with a small motor.
PG
That's the best suggestion I've seen so far! Hybrid automobiles and diesel-electric locomotives are both good examples of this principle.
http://www.parallax.com/Store/Robots/RollingRobots/OutdoorHybridRoboticPowerPlant/tabid/625/Default.aspx
PG
This would let you use a much weaker motor on front to direct the wheels and save the engine for serious power.
Post Edited (Ugha) : 5/15/2009 2:54:58 PM GMT
