Propeller 44-pin QFN?
How in the world would you connect the QFN chips to anything?· Would you have to use a custom PCB or some wire-wrap board?· I just can't picture in my mind's eye how you would hook one of those up...· Unless there is some special proto board that has an area designed for that specific chip...· ?
3.1415926535897932384626433832795028841971693993751058209749445923078164062
86208998628034825342117067982148086513282306647093844609550582231725359.....
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
both the 1x1 and full size are $5 for the pcb.
Personally I hope to do the dead bug soldering some day on this IC because I think it would be fun to see what it looks like and to say I have done it.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
(What I really mean is that I've tried using QFN chips and it's no fun!· If the lead spacing is big enough, it isn't so bad, but I wouldn't dare try using the Prop QFN without automated machinery.)
[noparse][[/noparse]Ok, it take that back.· The Prop QFN lead spacing is just enough that I might try it if I were desperate for space.]
Post Edited (Rayman) : 5/2/2009 2:54:11 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Word to the wise - don't try ironing clothes with it afterwards!
A (somewhat loony) acquaintance of mine bought some normally very expensive Xilinx Virtex BGA FPGAs cheap on Ebay, because they had been removed from PCBs, and experimented with them by gluing them upside down to a prototyping board and soldering wire-wrap wire to what remained of the balls. The same technique can be used with QFNs, of course, as Timothy has suggested.
Leon
Post Edited (Leon) : 5/2/2009 9:32:39 AM GMT
Leon
Phildapill, is that correct?
Leon
Thanks.
A reflow oven is pretty easy to do. It basically just heats up the whole board at a controlled rate, causing the solder paste to "reflow", i.e. melt and bond chips to board. Timothy D. Swieter made a good Prop Controlled version, but I can't find the post ATM. Timothy?
I think there is a need for a turnkey solution.... the stuff you guys take for granted would be news to people like me.
I wouldn't know where to start. There have been volumes said about it... and they are all lost to posterity... and to me[noparse]:)[/noparse]
What the world needs is a kit... so, when this question gets asked again.... the answer is... get mctrivia's kit[noparse]:)[/noparse]
This where serious hobbyists need to go... and there isn't a good way to get there right now.
Rich
rjo_: I know you have asked for a kit for the propmod. I have made a kit that includes all parts and a few spares of the really small caps and resisters for $12 for the 1x1. You need to get your own prop or add $12 and I will include one.
See pic.
Jim
P.S. I discovered where the Swine Flu started.
I thought you'd like to know.
My reflow toaster oven uses a Prop, the Parallax thermocouple kit, the LM9033a display from Brilldea and a couple buttons, leds and a piezo. It really isn't a kit, but eventually I can post more pictures. There is another thread on it around here. I didn't use relays to control the lights, fan or heating element but I used ac crossing detection and thyristors.
www.tdswieter.com
Dave
Dave,
Using a toaster oven, dual sided boards are possible. There are two things you must do to accomplish this. You must assemble them one side at a time, and you must hold the board up off the components on the second reflow.
The solder may go liquid on the second run (bottom side), but the surface tension of the solder will hold your parts on.
the skillet method only allows one side to be populated, if that was what you were asking.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
My new unsecure propmod both 1x1 and full size arriving soon.
