Purchased a TTL Level GPS
Not knowing what I was doing (as usual) I purchased a 32 Channel LS20031 GPS 5Hz Receiver that communicates via TTL. All the objects in the exchange for GPS seem to communicate at RS232. I goggled plans for converting the signal using a MAX232 chip, but before I get to deep into this I thought I might ask for advice. Has anybody used a TTL GPS with the propeller before?
Well maybe. I am trying to use the GPS_float object with Viewport, I may be goofing something up there.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
