AC current sensor research
I am cooking up some "green" ideas that involve monitoring current. Soon I will be moving to a new home and I thought a little home project of monitoring my electricity would be fun. While out and about I saw the Wattson device (www.diykyoto.com) in a store which inspiring me. I am thinking of making a system with a similar architecture and the part I am researching now is the current sensor/amp clamp portion. I could probably just buy an amp clamp from the company that makes the Wattson, but I thought I would ask around and see what other advice other users might have. The Wattson probe is here: shop.diykyoto.com/products/clip-for-2-or-3phase-system
The amp clamp should probably be a clamp so it can easily be added to the house wiring without removing and replacing any conductors. I know there were some other IC for measuring current, but I think those ICs required that the power be passed through the IC which would mean lifting a conductor or doing wiring. Maybe those ICs could be used to read the current probe/amp clamp.
My overall system will probably use a Propeller as the base microcontroller. I will probably have to build some interface circuitry to the amp clamp, which is fine.
So, any thought on sources for amp clamps like the Wattson version? Any other recommendation on best how to measure the AC current into the home? Any ideas on the interface circuitry?
Thank you.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Thank you.
www.tdswieter.com
Good luck!
Watching that, if possible, should be cheap, safe, accurate, and all sorts of good things.
Of course, if that's not an option, the clamp widget, plus a lot of fast sampling and maths are heading your way.
Bear in mind that, if you care about accuracy, you'll need to measure the voltage as well as the current. You can't simply assume the power is a nice sine wave, it'll undoubtedly be clipped, for a start.
(measuring the voltage at the output of a step-down isolated transformer should be fine, just be wary of the phase shift across it)
Steve
- Stephen
It's Only A Stupid Question If You Have Not Googled It First!!
Use a voltage divider to measure the 120V voltage. Use a Hall-effect sensor and measure the current. Write a program that would hunt for the "peaks" of voltage and peaks of current, record the values, and record the times between each. From these, it would be easy to calculate power AND phase angles.
I like to dream that if my little home experiment goes well that I could build an open source design and kit so that others could use it. My specialty would be more in the overall system concept and the embedded design. My short coming is in the tracking or logging software on the PC or web. This project probably won't be heavily "staffed" for a few weeks, so right now I am researching. I think I will want to get some hardware working by middle of June or so.
@Franklin - that is a great link. I am reading through that now, thank you.
@Brian Carpenter - I have seen this device mentioned in other threads. From what I can see I have to run the wire through the device because I am not able to put the device around the wire, true? In other words it isn't a split ring for clamping around the wire? I like that this device looks easy to use and I saw it mentioned in other threads on the forum.
www.tdswieter.com
http://www.google.org/powermeter/smarterpower.html
-dan
www.tdswieter.com
This is an interesting to me too - I have a bunch of computers networked together, but never really know how much juice they drink. Afterall, a PC's power supply, at 350 Watts say, is it's optimum max rating (I assume), but it probably doesn't pull that much unless the CPU is maxed and all the bays are full of whirring drives. So, if I add say ten PC's to the net, how much will my bill go up? It would be nice to know ahead of time for budgeting.
Keep in mind too that it would be cool for your device to account for 'reverse metering' for those of us futurists who would eventually like to have solar panels on the roof and generate a bumper crop of electrons!
cheers
- Howard in Florida
Buzz Whirr Click Repeat
www.tdswieter.com
http://www.weemscreeksolutions.com/energyconservationpowermonitors.htm?gclid=CNrippPqy5kCFRUhnAodEg8PuA
- H
I just came across these guys (I was looking at PTC's) and immediately thought of this thread. Not sure if any of these current sensors would work, but I think they would. Have a look. I'm in the process of buying a house also, and I will need to upgrade to 200amp service. This would be a good time to implement these!
www.amecon-magnetics.com/
www.amecon-magnetics.com/pdf/5300%20series.pdf
www.amecon-magnetics.com/pdf/5304.pdf
www.rtie.com/
I'm curious of the experts would think this would work. Seems like a good fit. No clue on prices though.
-Parsko
I have thought a lot about this idea, but haven't gotten into details. I have mostly been thinking about the system level and the larger pieces before getting back into the specific parts. I am looking forward to building this project when the time is right.
www.tdswieter.com
e.g.
http://veris.com/file_uploads/h722lc_i0a2.pdf
John
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
www.tdswieter.com
So, the plan would be...
-use a voltage version of the current transformer
-use an ADC (any recommendations, I see other threads I should search through)
-use a Propeller
I will probably create a simple PCB that has a Propeller, a couple connection points for the current clamps and maybe a socket for a WIZnet Ethernet module. What do you think?
What current rating clamps should I buy? In the USA I know branch circuits are usually 15amp or 20amp. I am not sure about Singapore (where I am moving to and where my little project would be in installed). I also want to stock clamps that are rated for the incoming power.
www.tdswieter.com
···· I threw a quick demo together .. Uses 722LC Hawkeye CT - 0-5v output (self powered). These have range settable 10A, 20A and 40A. I used an LTC1298CN8 ADC .. and a prop..
see attached images (low res. - sorry - from phone).and a small vid.
Demo shows a dual heating element - second one switched in and out.
Doh - spot the typo in the vid 'curremt' as opposed to 'current'
Rgds,
······ John
Post Edited (QuattroRS4) : 4/24/2009 12:04:31 AM GMT
I will be getting some current transformers from my Chinese source. I probably won't make much progress on this project until the June time frame though. So much going on until then and it is still April! Once I get the current transformers I will offer them through Brilldea so that we can collaborate together on a current measuring project or two.
www.tdswieter.com
Sounds good ! The Dev board I am using there is an EasyProp .. made by a friend Franz Achatz .. It is pretty damn cool. Can be powered via USB directly (great when travelling ... just connect usb programming connection to laptop !) or via separate power supply ... Has onboard enc28j60 ethernet,SDcard slot,Keyboard,Mouse,Composite,Vga,Audio, Xbee Header .. can be programmed via usb (has onboard FTDI) or prop plug.Has a nice SIL i/o header .. and is a very compact size ..100mmx80mm.
See it here ..
www.igniteautomation.com/easyprop.html
John Twomey
Not sure it its been mentioned above my reply, but:
I ran the propeller(via USB) into my home computer (it ran 24 hours a day) that ran a program (made it in Visual basic). That program sent text files up to my website (via FTP) where I can view from the web.
What your asking is not difficult by any means. Video, text, sound all can be done.
I haven't had a chance to try this current devices out just yet. But, I thought maybe a little encouragement and peer pressure from the forum would get me going again.
I am looking at the AMPLOC again (because I think the CTs I bought are too big for my breaker box), has anyone used them in detail? With some current transformer you have to loop the wire around the CT. With the AMPLOC you just pass the wire through, correct? I wish they offered a split core type of style to make it easier to install in exist location where you wouldn't want to disconnect the AC.
www.tdswieter.com
The loop you speak of is usually only employed when measuring low currents < 1 Amp .. A lot of the CT manufacturers specify a loop in these scenarios.
John
@John: thanks for posting the link back in April to the easyprop --- odd that I missed seeing that great looking board before.
thanks,
- Howard
www.tdswieter.com
No Problem - Yip the EasyProp is pretty cool .. Can be USB Powered, SD Card, Enc28j60, KB, Mouse, TV,VGA, Xbee slot nice SIL access to I/O's
Rgds,
John
'Those who can, do.Those who can’t, teach.'
'Convince a man against his will, he's of the same opinion still.'
I've just started looking at Xbee recently ... is using it and the ether/Enc28j60 on there draw too much for using USB power only?
thanks
- Howard
