Wifi+propeller
Has anyone used the Secure Socket iWiFi along with the propeller?
The problem is that it not leaves this loop:
i:= 0
repeat
serialPC.str(string("repeat"))
ppp:=serialIWi.rx
i++
while NOT(ppp[noparse][[/noparse]i-1]==$0D)
serialPC.str(@ppp[noparse][[/noparse]0])
serialPC.tx($0A)
serialPC.tx($0D)
i:= 0
repeat
ppp:=serialIWi.rx
i++
serialPC.tx($0A)
serialPC.tx($0D)
Por favor usa los tags [noparse][[/noparse] code ] and [noparse][[/noparse] / code ] (sin los espacios) para encerrar tu c
-repeat
----serialPC.str(string("repeat"))
----ppp:=serialIWi.rx
----i++
-while NOT(ppp[noparse][[/noparse]i-1]==$0D)
-serialPC.str(@ppp[noparse][[/noparse]0])
-serialPC.tx($0A)
-serialPC.tx($0D)
The while should not be inside the repeat ?
Edit: oh boy, the tag bite me :-(
Post Edited (Ale) : 4/29/2009 10:34:55 AM GMT
If "serialIWi.rx" returns a string, then you should read this before the loop.
You catch a new string form the rx-buffer each time you "loop" and you have just luck if you hit the $0D
Edit: If the "serialIWi.rx" only returns one char you don't save them in the position of variable "i" only in the first position..
then i would use
Don't take my thinking as facit.. I'm also fresh with propeller
Edit2: Using [noparse][[/noparse] i ] without spaces inside code don't work here..
Post Edited (KIH) : 4/29/2009 10:26:40 AM GMT
