Controling RCTIME
BS2
In the project I am working on I am comparing two RCtime values. Both of the values are between 100 and 600. I want to compare these two values and move a motor which will attempt to make the values the same. The problem I am having is that of course the values will never be the same so I need to allow for some allowed error.
I am trying to do this with IF statements by saying if a value is between say 200 and 300 then the value is 250, this would mean for any value between 200 and 300 the real value would be 250. This would stop the problem as the variables would need to change a lot before something happens.
The if statement I tried to use (and its wrong) was
IF man >=200 AND man <300 THEN man =250
My problem is trying to get the if statement to make sure two values are true and I cannot seem to be able to do this.
Post Edited (vinnyirl) : 4/29/2009 3:01:59 AM GMT
- Stephen
IF (statement 1) AND (statement 2) THEN do stuff
I have moved away from if statements in my program, I am now trying PID control http://forums.parallax.com/forums/?f=5&m=347572&g=347572#m347572
although this is still unsuccessful
a copy of my program
' {$STAMP BS2}
' {$PBASIC 2.5}
Define variables, set status of pins
x VAR Word
cnt VAR Word
RC PIN 0
man VAR Word
cont VAR Word
Constant declarations
S0 PIN 11 'Sensitivity selection pins
S1 PIN 10
IN PIN 9 'TSL230 output pin
Program Start
start:
IF IN2 = 0 THEN GOTO main
IF IN2 = 1 THEN GOTO start
GOTO start
main:
LOW S0 'Set sensitivity pins (S0,S1) to x10
HIGH S1
FLC
COUNT IN, 100, cnt 'COUNT on P2 FOR 100 ms, store value in cnt
IF cnt <150 THEN cnt =105
PAUSE 100
DEBUG HOME, DEC3 cnt 'Display value of cnt, as a decimal
'----Manual Adjust----
HIGH RC ' charge the cap
PAUSE 100 ' for 1 ms
RCTIME RC, 1, man ' measure RC discharge time
IF man <150 THEN man =105
DEBUG CR, DEC man,CR ' display value
PAUSE 1
'---PID---
cont = cnt - man
DEBUG DEC3 cont
'---Compare---
IF cont = 0 THEN off
IF cont < 50 THEN left
IF cont > -50 THEN right
GOTO start
off:
LOW 6
LOW 7
GOTO start
left:
HIGH 6
HIGH 7
GOTO start
right:
HIGH 6
LOW 7
GOTO start
The syntax of your original statement is fine and will change a starting value in the range of 200 to 300 to a final value of 250.
and in what sense is it "wrong"?
The new program also uses plenty of IF statements, but one thing you can't do in Stamp logic is negative numbers as in
> IF cont > -50 THEN right <--- won't work like you expect
The compare logic does not make sense in the program. Partly because it is comparing a COUNT value with an RCTIME value, and I don't see the physics behind that. Also because any cont value between -50 and 50 satisfies the conditions to go both left and right.
Tracy Allen
www.emesystems.com
