VPP Generation error
Hi All,
I'm a newbie to the SX so be gentle!
I've just installed SX-Key Editor v3.2.92h BETA, updated the USB drivers and I'm trying to program a Robolympics medal using a SX-Key USB.
I'm using the Badge.SXB code from the Parallax website with a small modification to the text that it's suppoded to write on the badges display.
The program compiles fine but I get a "VPP Generation Error" message when programming and the badges OEM program continues to run.
I'm using Vista and I'm thinking that this is some kind of interaction between it and the USB drivers for the SX-Key.
Has anyone else encountered this or des anyone have any thoughts on how to get rid of the error?
Kevin
Kevin
I wonder if you need an external 5v power supply, isn't the onboard batteries only 3.3v? If they are 5v, maybe you need fresh batteries?
Or maybe you could use a sx-keyring if you have one.
You shouldn't need any external voltages because the USB version of the SX-Key gets power from the USB port.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Post Edited (Bean (Hitt Consulting)) : 4/28/2009 12:36:20 PM GMT
Never mind, Bean was right I did have the SX-Key upside down.
Didn't think they would make it so that you would rub up against the SX chip and didn't want to take the chance of physically damaging it but I tried it and it works!
Thanks Bean.
