LIDE and or CIS image sensor interfacing.
Clock Loop
                    I am interested in using the LIDE scanner led, or the CIS sensor in my old scanner.  I would like to use the new LIDE cannon sensors, I don't mind buying a scanner if someone has progress on getting the sensor to work,...
Does anyone have any INFO on doing this? I have an sx chip, basic stamp, and I can also interface to a fpga, and or DSP combination.
I guess my question is if anyone has done this interface with a sx or basic stamp or even propeller?
Im looking for a quick and dirty example of interfacing to a LIDE (cis) sensor. I am willing to interface the sensor directly, or somehow interface it thru USB.
I throw out USB because this means I need to interface usb, program a driver that comms with the scanner thru the usb interface.
It would be eaiser to just buy a new cannon, tear the chip out and use it.
I guess my biggest issue is finding what scanner has the sensor data sheets available.
Ive looked up available sensor chips with datasheets but those chips are more expensive than a 60$ scanner.
Heck, if I had a scope id try to just rev-engineer it.
Anyone?
Meh. Nothing here, move along.
Anyone?
- Stephen
My question here was asking if anyone has worked with any flatbed scanner sensors, or know of any flatbed scanner sensors that are affordable.
I am now looking into if I need a propeller or if I can process signals with an sx. Or I might need a fpga/dsp combo.
I'll post info here if I find that using an sx or propeller is practical in any way when it comes to using this kind of sensor.
