38kHz Detection Question
                    So i have been playing around with the Stamp Stack II (solarbotics advertises a 100% compatable to Parallax BS2). Anyways, I have not found better documentation or instruction than parallax Robotics With The Boe-Bot. The stamp stack is designed to slip on to a breadboard, which is nice. I am currently using some 38kHz IR detectors hooked up to pins 0 and an IR Led hooked up to pin 1. My question is that the documentation for the BOE BOT is saying to hook the IR LED up to pin x through a 1k resistor (and i have tried many different combonations.) The problem i am having is that hooked up the way the documentation says, i have to actually run a 36000 PWM and I only get about 2-3 inches of detection. I took it upon myself to build a 5v regulator with a LM317, so I used a 2n2222 along with my output pin from the STAMP to switch 5v to the IR LED through a 1k resistor. Now I get 18 - 20 inches of solid range at 38kHz. Is this a common problem with the STAMP modules?
-Mike
······ I'll try everything once [noparse]:)[/noparse]
                            -Mike
Next step is a motor driver for my gear motors.
