after a horrible week of ordering and a bunch of wrong shipments
I have recieved my stepper motors in the mail. I ordered 3 unipolar stepper motors with a controller for each, turns out that after some research the controller i order is for a bipolar stepper motor. i have a project due this friday may 1. is there anyway to rig the motors or the controller to make them compatable. the reason i found out about the controller being wrong, was because i saw it on sparkfun after i order from the one place. Also is there a way for me to quickly throw together a controller if they are not at all compatible. any help is deeply appreciated.
- Stephen
There is a 4 wire bipolar stepper. I helped a guy on Sparkfun's site with this.
The polarity of the winding change as it revolves (hence bipolar). You can search for 4 wire bipolar stepper, and find some diagrams. A 4 wire bipolar requires an H bridge to run (since the polarity changes on the windings).
Unipolar have 5 wires (one is ground), bipolar have 4 or 6 (the 6 wire version has 2 grounds, one for each winding).
I did an extensive search, but you are free to do your own if you wish.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
The 4-wire motor can only be driven by bipolar waveforms. The 6-wire motor, the most common arrangement, is intended for unipolar drive because of the center taps. Though, it may be driven by bipolar waves if the center taps are ignored. The 5-wire motor can only be driven by unipolar waves, as the common center tap interferes if both windings are energized simultaneously. The 8-wire configuration is rare, but provides maximum flexibility. It may be wired for unipolar drive as for the 6-wire or 5-wire motor. A pair of coils may be connected in series for high voltage bipolar low current drive, or in parallel for low voltage high current drive.
A bifilar winding is produced by winding the coils with two wires in parallel, often a red and green enameled wire. This method produces exact 1:1 turns ratios for center tapped windings. This winding method is applicable to all but the 4-wire arrangement above.
Aka: CosmicBob
