PSC serial info and pin outs?
Can anyone provide the pin out information for the Serial connector on the Parallax USB Servo Controller? I've had 2 of these for quite some time but never used them, so I hope to put them to work in a project we're working on. Why did you folks discontinue it? Pretty nifty device. What serial standard is the serial port, RS232? I'd like to use serial versus USB because the controller will be 100 - 200 feet away from the computer.
I saw the Parallax USB Servo controller in the May 09' Jameco catalog I just got in the mail. It says it has Doc.s for it.
The Jameco part# is 387962
___Maybe this will be of some help________$WMc%__________
The Truth is out there············································ BoogerWoods, FL. USA
The USB version of the PSC uses the same serial interface as does the serial version of the PSC. You can use the same documentation of the commands and the connections.
- Stephen
