What to use for power on/off
Hi, basically i want to control the power to a set of 12 volt led strips.· i know that the prop can't power them themselves, so what i'm wondering is what you recommend.· basically, when a distance triggers from an infrared sensor, i want the lights to be able to blink on and off at a specified pattern.· If you have a recommendation, if you can include part numbers so that i can look up the pieces.· Thanks!
Russ
Russ
Edit:· After looking at that, honestly i've never used a transister, can i get a link to a tutorial on them, or a quick tutorial?· I'm guessing out of the 3 pins, one is a trigger pin, and the other two just pass the current?· so if i have one pin hooked to a pin of the propeller, and i send a high to it, then the voltage coming in one pin will go through the other pin.· how much current can i pass through?· lets say the led strip uses 1 amp of current, is that going to be ok?· I've seen some talk before about transistors being dangerous for the prop?· how might that be?· sorry for my complete lack of knowledge on the subject.· Thanks in advance!
Post Edited (russ christensen) : 4/24/2009 8:16:25 PM GMT
Read the Wikipedia article on relays (do a websearch on "wiki relay").
You would use a transistor as described in the Nuts and Volts article to control a relay designed for the voltage and current you need.
This one from RadioShack would be powered by your Stamp's power supply (5V) and can switch up to 1A: www.radioshack.com/product/index.jsp?productId=2062480. RadioShack has some other relays that would be powered by your 12V supply and could switch as much as 10A. You'd still use the transistor to control the relay as described in the Nuts and Volts article.
Russ
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
I'm not an expert... and if I say anything wrong I hope someone jumps on it.
Like you, I thought that a transistor was a transistor and the only difference was in the sizing and cost... not at all.
In my case I just wanted to use my Prop to switch 5V... to replace a reed relay. All of the guys told me not to use reed relays and I didn't listen... and I was perfectly happy until I got to a point where I wanted to pass an amp and switch very quickly and the thing tended to stick open. I tried using a switching transistor from RadioShack... expecting that if my source was 5V... I'd get 5V at the drain... not true... I got my gate voltage at the drain (and they call these things amplifiers?[noparse]:)[/noparse]
However... if you spend just a little more money, you can get what you want and expect[noparse]:)[/noparse] An FET... or more specifically MPF102... cat #276-2062 from Radioshack actually works the way I thought they all worked[noparse]:)[/noparse] And the packaging is (quite exceptionally) very clear on the connections. With a mosfet design, the signal going to the base does not mix with the current being switched... which seems like the way it should be and the way I thought they all are[noparse]:)[/noparse].
You are looking for an 1A... The package says that the MPF102 "dissipates 310mW"... usually a package will tell you how much current you can pass along. So, I'm not exactly sure what this means... it could mean that the moment before you blow it up, it will be moderately warm[noparse]:)[/noparse] If that is the case you can feel free to blow it up without starting a fire.
I'd buy 4 of these... if the first one blows up, hook up the other 3 in parallel[noparse]:)[/noparse] ... the package says that the gate current is 10mA... so you should be able to drive 3 from a single Prop pin.
Rich
A MOSFET, like the IRF510, can be thought of as a variable resistor; the resistance from the Source to the Drain is controlled by the Gate voltage, or more accurately by the Gate voltage with respect to the source voltage. However, it's not a perfect device; a graph of resistance S-D vs Gate voltage is not a straight line.
Vgs(th) is the gate voltage at which the device first starts to pass current. If we look at the graph below we see that little current flows until Vgs is about 4 volts; with a maximum of 3v3 from the Prop you may find the device does not conduct enough for your needs. In contrast, there are devices like the IRL510 which have a much lower Vgs(th) which are designed to work from low voltage logic levels. This can be seen in the second graph where we can see that 3v3 will cause a current of about 2A to flow.
Your questions regarding t(d)on and t(d)off - these figures give the speed at which the device will turn on and off and are not related to the width of your driving signal. If you could feed the device with a pulse which instantly went from low to high then the FET would respond by dropping its resistance over a period of 20ns.
