Unsecure PropMod
Well I have had several people say they are interested in my propmod but don't need the code security. So I have built a new module with similar options but with things located in different places and without the epoxy.
The uSD card reader is now on the top. EEPROM and programing header are now on the bottom. I have added a buck/boos power supply to the board and removed the RTC.
It is late so I will post some drawings tomorow.
Check here for info about original propModule
This new module has the following features:
*512k EEPROM
*5MHz Crystal
*Programing Header
*Pin Compatible with secure module except clockout has been replaced with P29
*Price $30US
Options available:
*uSD card reader($4 US)
*buck boost converter takes an input from 1.8V to 5.5V and outputs 3.3V at 0.8A($10 US)
Blank PCB available for $5 US
I need to sell at least 20 of the PCB or full boards to make this product.
Does anyone want one?
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
*512k EEPROM
*5MHz Crystal
*Programing Header
*Price $30US
Options available:
Pin out*:
*Pin 37 is actually P29
so far no one else has said they want. I do need to sell 20 min to cover production costs.
anyone else want some?
Bill
I will panelise them together so the minimum order of 20 total amongst everyone will be along all 3 of my prop mod designs. Price for this new layout will be the same. $5 for PCB $30 assembled.
Please note this board has no extra options.
0.1" Grid.
Pins:
Bottom Header:
Pin 1 : GND
Pin 2 - 9 : P0-7
Pin 10 : Reset
Pin 11-18 : P8-15
Top Header:
Pin 18: Gnd
Pin 1: Vdd
Pin 2-17: P16-31
Programing head is throug whole and can be left blank or with straight pins
EEPROM and crystal are on back.
Is that quick enough for you?
I like the idea of having everything in a small package, especially with the card reader. It is unclear to me though if it can be hooked up directly to a battery or if it must be inserted into a board with regulated power. For example, could I just plug in a battery and a couple servos (powered separately) and have a mini robot?
Recently frying a couple chips has me more concerned with how things are hooked up.
Rich H
I would want the one with that power supply, would I need to add caps? I didn't see any in the diagram - but then that diagram was for the RTC...
Rich H
As a note the power supply will take any voltage from 1.8V to 5.5V and give 3.3V out.
Post Edited (mctrivia) : 4/22/2009 5:11:07 AM GMT
Totally missed that! I was looking at the diagram on the other thread.
Count me in for one, with card reader & power supply.
Rich H
Also I just figured out flights to get to the expo will be a grand so I can't make it this year.
I don't need exact numbers but it is good to know which designs I should make more of then the others. I have 155 square inches to split up between the different designs.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
*Pay Pal
*Any Major Credit Card(Through PayPal)
*Check
*Money Order
*Cash for local pickups only
--Steve
Would be uch easier if I was using leaded boards. Lead free is not as nice to work with but since I want these to be universally allowed rosh compliant they must be,
Post Edited (mctrivia) : 4/25/2009 1:03:23 AM GMT
Soldering QFNs with a soldering iron isn't difficult if the pads are extended a bit. Plenty of gel flux and drag soldering works very well.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
