String to Number method
I'm looking for a method (or object) that would convert an ASCII string to an integer number.··Specifically, I want to use desired track, ground track, magnetic variation, and cross track error·from an NMEA string downloaded from a Garmin GPS in a navigation project.· In a recent post, StephanL38 referenced a StrToDec-method but I have been unable to locate it.
Jim
Jim
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
Post Edited (ProcessingData...) : 4/23/2009 5:11:28 PM GMT
START:·
>Saving Data. . . .
>Signing OFF
Thanks very much, I had not looked in the PLUS version of FDS.
Jim
I'm new to Spin and programming with methods and objects - most of my experience has been with 68HC11 and hex machine code.
Cheers,
Simon
www.norfolkhelicopterclub.com
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again
