Leg joints and physics...
I'm designing a rather large multi-legged robot. I'm planning on using some rather high-torqe motors and gear boxes to move the joints. One thing I've been wondering is whether I should directly couple the gear box to the joint via a chain drive (emulating the way walkers are currently done), or to try a more biological approach? In the biological approach, I'd still use a chain, but the ends of the chain would have cables attached and the cables would be connected to the next leg segment. This would pretty much emulate a muscle/tendon/bone set up.
The big question is which would be better in terms of power and preformance? It looks to me that the typical set up of placing servos at the joints is necessitated solely by space and weight constraints. I would expect the biological system to outperform such a system, but I cannot figure out how to best determine this. The best way I can look at it is to consider a bone/joint as a lever with the beam (bone) cut in half at the fulcrum(joint). Current systems place the motor at the fulcrum while a biological system places the motor behind the fulcrum and uses tendons to pull on the beam directly. Physics is not my thing and the only way I can figure this out would be to build a half lever device, but I lack the tools to test the forces. I would guess that more torqe would be required to move the beam at the fulcrum than by pulling on the beam, but with the beam cut in half, I also guess that quite a bit, if not all, of the benefits of a lever would disappear.
Can anyone provide some insight here? It would be much appreciated.
Mark
Mark
Referring to the attached picture, if you put a mass at point A and it takes a force F to lift it, moving the mass to point B will require twice the force to lift it. The same applies to the motors on a robot arm.
The motors will be placed on the legs, close to the joints and parallel to the leg. Miter gears will be used due to the orientation of the motors, but placing the motors inline with the leg will allow the use of much more powerful motors in less space.
I guess my question is, which design would be best?
So, um, no.
Post Edited (MarkS) : 4/20/2009 6:24:03 AM GMT
some links:
www.thirdwave.de/3w/tech/actuators/mckibben.pdf
brl.ee.washington.edu/Research_Past/Biologically_Based/Device_01_McKibben/Mckibben.html
brl.ee.washington.edu/Research_Past/Biologically_Based/Device_01_McKibben/Mckibben_Costruction.html
And video of them in action:
www.youtube.com/watch?v=pDvDfJL3--0
www.youtube.com/watch?v=YJbl61WmLoU&feature=related
I really have given the motion control a great deal of thought. I've weighed the pros and cons of each different type of system and have gone back and forth between them all, but I keep ending up at a simple motor-based system. It is simply the cheapest and easiest system to construct.
Anyway, I think my original question has been answered.
