Mapping heat?
                    I was just wondering, how is it done? I know Parallax sells ir heat sensors, however they are not capable of creating maps unless you move it around on a servo. So, how is it done only using a stationary sensor?
PG
PG
http://www.melexis.com/News/Developing_an_IR_Sensor_Array_for_Multizone_Temperature_323.aspx
Unfortunately, it doesn't say anything about how it works, and when I tried going to the page for it I got an error message (404). Do any of you know a place where I can get more info?
PG
http://www.robotshop.us/devantech-8-pixel-thermal-array-sensor.html
But I must say I am somewhat disappointed by the price. If any of you come across one which is cheaper, let me know. I could really use one of these in my project.
PG
Main source: http://www.atsf.co.uk/ilight/tech/thermal.html
Most consumer cameras can see infrared light of one kind or another. To get the heat of an object, we use the emitted infrared light, as opposed to the reflected infrared most IR photos use. Therefore, we have to filter out those wavelengths of IR that are reflected (near-infrared), so you'll have to get a filter for that. You'll have to also filter out visible and UV light too. What's left is far-infrared (after the filters). Since the regular lens of a camera will block far-infrared, you get rid of it. Instead, you use a camera obscura with a pinhole. To increase the number of items that you can reliably photograph, you can chill the camera close to it's minim operating temperature. A special outdoor camera would be good for this, as would probably a security camera that's made to use infrared for night time.
Granted, this system wouldn't work as well as a custom system. In particular, it would only detect hot objects or no objects (hot being some relative term, maybe a soldering iron). I assume a consumer digital camera can see the required wavelength for hot objects based on these two sets of photos:
http://www.flickr.com/photos/jatherton/2772731563/in/set-72157602207040035/
http://www.flickr.com/photos/ciordia/335124406/
The wavelenngths Pi Guy is talking about are much higher and require thermopile detector elements, not photodiodes.
IR as in a remote control is just outside the visable spectrum. But thermal IR is ALOT longer wavelength. Not even the same animal.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
"Clark explains that infrared photography can see hot bodies at temperatures from about 250 C up to the point where they begin to glow visibly at about 500-600 C, depending on how dark it is and how much your eyes have adjusted to the darkness."
This won't work because my main application for it is detecting people. That's why I wanted the images to·be mapped, so I could ensure it was truly a person, not a·fire or a piece of metal sitting out in the sun.
PG
Post Edited (LilDi) : 4/22/2009 4:20:43 PM GMT
PG
www.irisys.co.uk
They make low-cost thermal imagers (under $1,000 IIRC). They are selling like hot cakes, because of the swine flu scare.
I worked on the prototype, which used their 16x16 sensor array with a rotating chopper and a germanium lens.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 5/4/2009 4:16:34 AM GMT
PG
Leon
PG
Maybe I should just stick with that 100 buck array.
PG
