AM FM HD Radio with prop?
tonyp12
Just using minimal external items, no IC chips.
Would it be possible to digitize a AM/FM signal and play it back with prop.
This would be a good exercise in understanding AM/FM·Radio
Decompress HD (hybrid) maybe not be possible
as it's similar to MP3 and the prop may not have the horse power.
As few external component as possible, so the prop will handle all of the demodulation in software.
AM radio receiver with the Propeller not long ago?
Might be a helpful link if someone can lay hands on it.
OBC
New to the Propeller?
Actually I am wondering if the threshold of a prop input is precise enough to handle such small signals. microphone_to_headphone.spin delivers lots of noise on my demo board. Okay, in worst case you simply have to add a fast comparator.
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
For FM you would need an external downconverter, since the frequency band is much higher.
Compressed audio exists up to somewhere between 5Khz and 8Khz. Above that, spectral replication is used to convey those sounds.
And that is why HD radio is more about the perception of high resolution, instead of actually being high resolution. Typical bitrates seen in real broadcasts range from 36Kbps (AM HD) to 96Kbps. (Most FM HD radio broadcasts)
The actual HD radio broadcast rule making permits ANY codec to be used. They had to do this because of the public interest. Truth is, ALL HD broadcasts are done with the Ibiquity codec, and each receiver is a licensed work, payable to Ibiquity.
If the codec were to be reverse engineered, the computational requirements are very high. That is why there are not yet any cheap, portable HD radios!!
For a good overview of the tech, I wrote a paper on it, just as HD was beginning US broadcast trials. It can be found here: http://opengeek.blogspot.com/2005/03/hd-radio-thoughts-speculation-and.html
IMHO, this is all off limits to the Prop I.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
