IR remote help
I am trying to use the IR remote object and I can't quite get it to work.
I would like to set a pin (13) high if chUp is pressed, and set a pin (14) high if chDn is pressed.
This is probably really easy, but please bear with me as I am still learning.
Thanks.
The pessimist is never disappointed.
Thanks.
PUB Main DirA[noparse][[/noparse]6] := In 'Sets pin 6 to In Dira[noparse][[/noparse]13] := Out 'Sets pin 13 to Out Dira[noparse][[/noparse]14] := Out 'Sets pin 14 to Out Outa[noparse][[/noparse]13] := 0 'Sets pin 13 to Low Outa[noparse][[/noparse]14] := 0 'Sets pin 14 to Low Start(6, @code) repeat value := GetSonyCode(6, @code) if value == 16 outa[noparse][[/noparse]13] := 1 elseif value == 17 outa[noparse][[/noparse]14] := 1 PUB Start(Pin, addrMainCode) : result {{ Pin - propeller pin connected to IR receiver addrMainCode - address of keycode variable in main memory }} stop byte[noparse][[/noparse]addrMainCode] := NoNewCode cog := cognew(getSonycode(Pin, addrMainCode), @Stack) + 1 result := cog PUB Stop {{ stop cog if in use }} if cog cogstop(cog~ -1) PUB getSonyCode(pin, addrMainCode) | irCode, index, pulseWidth, lockID {{ Decode the Sony TV Remote key code from pulses received by the IR receiver }} ' wait for idle period (ir receiver output = 1 for gapMin) ' comment out "auto repeat" code if auto key repeat is desired ' start of "auto repeat" code section dira[noparse][[/noparse]pin]~ index := 0 repeat if ina[noparse][[/noparse]Pin] == 1 index++ else index := 0 while index < gapMin ' end of "auto repeat" code section frqa := 1 ctra := 0 dira[noparse][[/noparse]pin]~ ' wait for a start pulse ( width > startBitMin and < startBitMax ) repeat ctra := (%10101 << 26 ) | (PIN) ' accumulate while A = 0 waitpne(0 << pin, |< Pin, 0) phsa:=0 ' zero width waitpeq(0 << pin, |< Pin, 0) ' start counting waitpne(0 << pin, |< Pin, 0) ' stop counting pulseWidth := phsa / (clkfreq / 1_000_000) + 1 while ((pulseWidth < startBitMin) OR (pulseWidth > startBitMax)) ' read in next 12 bits index := 0 irCode := 0 repeat ctra := (%10101 << 26 ) | (PIN) ' accumulate while A = 0 waitpne(0 << pin, |< Pin, 0) phsa:=0 ' zero width waitpeq(0 << pin, |< Pin, 0) ' start counting waitpne(0 << pin, |< Pin, 0) ' stop counting pulseWidth := phsa / (clkfreq / 1_000_000) + 1 if (pulseWidth > oneBitMin) AND (pulseWidth < oneBitMax) irCode := irCode + (1 << index) index++ while index < 11 irCode := irCode & $7f ' mask off upper 5 bits byte[noparse][[/noparse]addrMainCode] := irCode
The driver writes the code of the key pressed at the IR control to the variable for which you gave the adress in the start function.
Another thing: As the driver uses the pin, there is no need to set DIRA[noparse][[/noparse]6] to anything - each COG has it's own DIRA register and the direction has to be set by the driver.
So, in your repeat loop you simply use the code variable instead of the value.
