Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
HS1101 Relative Humidity Sensor distance from microprocessor? — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Accessories
Capdiamont
218
2009-04-18 14:31
edited 2009-04-20 00:37
in
Accessories
How far away can you place one?
Franklin
4,747
2009-04-18 14:57
edited 2009-04-18 14:57
How do you plan to connect it?
- Stephen
Capdiamont
218
2009-04-18 21:19
edited 2009-04-18 21:19
per the docs, is a method that looks short range.
kwinn
8,697
2009-04-18 22:02
edited 2009-04-18 22:02
Looks to me like you could use the 555 circuit in the data sheet, measure the frequency, and put it as far away as you want.
Capdiamont
218
2009-04-19 00:00
edited 2009-04-19 00:00
More parts that version, interesting though. Looks like the 555 circuit can be temp compensated. 3.5 to 12v. How long with parallax's circuit?
kwinn
8,697
2009-04-19 13:58
edited 2009-04-19 13:58
How far away do you want to put it?
Capdiamont
218
2009-04-19 15:59
edited 2009-04-19 15:59
My idea is to have two, and ordered two, to measure the difference in humidity between rooms, or inside and outside.
kwinn
8,697
2009-04-20 00:37
So we are talking about less than 50 feet. I would run some cat5 or phone cable to the outside sensor to provide power on one pair and return the 555 signal on the second pair.
Sign In
Register
to comment.
- Stephen
