MatrixOrbital LK204-25 / MAX233A / BS2 connection
I have·a LK204-25 Serial LCD with a·RS232·D-sub connector. The protocol solder jumpers are set for RS232 (rather than TTL or I2C).
I want to preserve·the current·LCD configuration but have the option of using it with a BS2 by using a MAX233A driver. I have the MAX233A socketed on a small PCB with connections for both·RX/TX·pairs and have no problem using it to connect to the PC.
Even thought the LCD is setup for 9600 baud, I can't get it to function with the MAX233A (it works when connected to the PC serial port with a straight-thru serial cable).·
Here is the wiring scheme:
LK204-25__________________ MAX233A___________ Basic Stamp
RS232 || TTL
DB9 pin 2 (RX)··<-- pin 18 (T2out) || pin 1 (T2in)···· <-- Serout
DB9 pin 3 (TX)··--> pin 19 (R2in) ..||. pin 20 (R2out) --> Serin
http://datasheets.maxim-ic.com/en/ds/MAX220-MAX249.pdf (Figure 11)
I tried swapping the D-sub RX/TX pin2/pin3 wires with no sucess.
Any suggestions?
Thanks!
RS232 || TTL
Any suggestions?
Thanks!
····· Thanks for your suggestions. I have it working now. I thought I had swapped the TX/RX DB9 pins coming out of the MAX233A but didn't.
I tried it again and everything works perfectly...
It should be like this:
RS232 || TTL
DB9 pin·3 (TX)··<-- pin 18 (T2out) || pin 1 (T2in)···· <-- Serout
DB9 pin·2 (RX)··--> pin 19 (R2in) ..||. pin 20 (R2out) --> Serin
NOT THIS
RS232 || TTL
