Point-to-point EIA-422
Hi,
I'm attempting to implement RS-422 in a point-to-point configuration to replace a RS-232 setup I have (for longer distances, higher noise immunity, etc.) I'm thinking of obtaining some SN75179BP ICs (http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMutXGli8Ay4kLJm31Vsi2pIdTq%252bzqwUdjY%3d)·to implement full-duplex over UTP·wire like Cat3 cable and·connect them with modular connectors.
The question is I don't know if I'm supposed to use any biasing or terminating resistors in a point-to-point setup. A National appnote (http://www.national.com/an/AN/AN-1031.pdf) shows a point-to-point setup with the driver and receiver connected together (+ to +, - to -, etc.) with no resistors, but with a suggestion to use TransZorbs.
Your second opinion·is much appreciated!
For practical application notes, B & B Electronics has numerous white papers free for downloading.
Cheers,
Tom Sisk
http://www.siskconsult.com
I·may use the fail-safe termination scheme (see image below, from http://www.maxim-ic.com/appnotes.cfm/an_pk/723/) at the receiver end because the receiver in the SN75179 has an undefined output if there isn't a voltage difference between them (which will happen if the cable is disconnected). The pullup/pulldown resistors should force the lines to a known state. I will test this out.
Since some of the nodes will be in a remote location and are low-current consuming, I will obtain 6 conductor UTP, 4 for the full duplex differential lines, 1 for power (it will be higher than +5V, since cable losses must be taken into account), and 1 for ground.
I used CAT5 cable: one pair for the communication (half-duplex, multi-drop), two pairs parallelled for the 12 VDC supply to the remote stations, the rest as spares.
BTW, Jan Axelsons's book "Serial Port Complete" has some very practical pointers on serial communication in all its flavours.
Cheers,
Tom Sisk
