4 PWM problem
Hello, I am new to propeller, please help, I am out of ideas what is wrong. I have used PWMasm module from object exchange.
So I would like to drive 4 motors using allegro A3649 chips. So far so good. Motors are running, but I can't get running all 4 pwm cogs. I get only any 2 of them.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 '! led = 27 pwm1pin = 18 ' engine 1 pwm2pin = 16 ' engine 2 pwm3pin = 14 ' engine 3 pwm4pin = 11 ' engine 4 pog = 1 OBJ pwm1 : "pwmasm" pwm2 : "pwmasm" pwm3 : "pwmasm" pwm4 : "pwmasm" PUB init waitpeq(|< pog, |< pog, 0) 'Wait for pog to go high dira[noparse][[/noparse]led]~~ outa[noparse][[/noparse]led]~~ ' LED on waitcnt(clkfreq * 5 + cnt) ' PAUSE 5 s outa[noparse][[/noparse]led]~ 'LED off main PUB MAIN pwm1.start(pwm1pin) pwm2.start(pwm2pin) pwm3.start(pwm3pin) pwm4.start(pwm4pin) pwm1.SetPeriod(80000) pwm2.SetPeriod(80000) pwm3.SetPeriod(80000) pwm4.SetPeriod(80000) pwm1.SetDuty(20) pwm2.SetDuty(20) pwm3.SetDuty(20) pwm4.SetDuty(20)
{A simple pwm object based on code from AN001 - propeller counters Author: Jev Kuznetsov date : 16 Oktober 2007 usage OBJ pwm : pwmAsm .... pwm.start( Pin) ' start pwm pwm.SetPeriod( period ) ' set pwm period in clock cycles pwm.SetDuty( duty) ' set duty in % pwm.Stop } CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long cogon, cog long sDuty ' order important (the variables are read from memory in this order) long sPinOut long sCtraVal long sPeriod PUB Start( Pin) : okay 'start pwm on Pin @ 80 kHz longfill(@sDuty, 0, 4) sDuty := 50 ' default duty sPinOut := |< Pin sCtraVal := %00100 << 26 + Pin sPeriod := 1000 cognew(@entry,@sDuty) PUB stop '' Stop object - frees a cog if cogon~ cogstop(cog) longfill(@sDuty, 0, 4) PUB SetPeriod(counts) ' set pwm period in clock cycles, frequency = (_clkfreq / period) sPeriod := counts PUB SetDuty(counts) if (counts < 0) counts := 0 if (counts > 100) counts := 100 sDuty :=counts*sPeriod/100 DAT 'assembly cog which updates the PWM cycle on APIN 'for audio PWM, fundamental freq which must be out of auditory range (period < 50µS) org entry mov t1,par 'get first parameter rdlong value, t1 add t1,#4 rdlong pinOut, t1 or dira, pinOut ' set pinOut to output add t1, #4 rdlong ctraval, t1 mov ctra, ctraval 'establish counter A mode and APIN add t1, #4 rdlong period, t1 mov frqa, #1 'set counter to increment 1 each cycle mov time, cnt 'record current time add time, period 'establish next period :loop rdlong value, par 'get an up to date pulse width waitcnt time, period 'wait until next period neg phsa, value 'back up phsa so that it trips "value" cycles from now jmp #:loop 'loop for next cycle period res 1 time res 1 value res 1 t1 res 1 pinOut res 1 ctraval res 1
Commented out the wait for pong to go high line since I have no switch on the Demoboard.
Changed the pin constants to pins with LEDs on the Demoboard
Running the program all 4 of the pwm pins light up which leads me to believe that all 4 pwm cogs have started. Is the posted program your complete program? If your program is longer could it be starting other cogs?
John Abshier
But the problem is still there.
I mesured actual outputs and get the following:
If I comment out or change order I could get PWM on any 2 pins but not on all 4 simultaneous.
For a moment yes, but it is only for a test purposes of my new 4 wheel mini sumo robot.
this cannot be a full program.
where is the OBJ-section
where is the CON-section ?
if your program has only a few lines more please post the COMPLETE program here
best regards
Stefan
