Attempt at a Propeller lie detector : Need truthful input
I'm working on an idea for a Propeller based Lie Detector using
uController's Game Stacker/Spin Studio board.
The idea is to make use of his RGB led, blue for normal, red when lie is detected.
I thought I *might* be able to use the RC time code from the PEkit Labs,
starting with RC Resistance Meter using prop-plug pins 30,31 for reading
the leads (pictured below) and then reporting the data to the screen.
The RC Delay circuit calls for a 0.01uf cap between the two I/O pins, but
it looks like there is too much "skin resistance" for this to work reliably.
Someone with a little more EE knowledge care to help me sort out what
I can add to this circuit to make this work?
OBC
New to the Propeller?
OBC
is between 500 and 1500 ohms. (Depending on skin moisture and cleanness)
Perhaps I need to add an additional resistor in line to get the levels
closer to intended values for the spin code. (10k)
Still open for expert opinions. [noparse]:)[/noparse]
OBC
Post Edited (Oldbitcollector) : 4/17/2009 4:19:50 AM GMT
I'm sorry I can't come up with anything better than to say "nope, that's not it", but I just see this approach causing problems.
Maybe it's how you ask things, and duration in between tough questions that is needed. Maybe it's not so much a harware question afterall...
Info Source: en.wikipedia.org/wiki/Electric_shock
And that's the truth
Aka: CosmicBob
Not sure about the lie detecting part, but here is something you can try in lieu of using RCtime.· I tried this with so-so results; I think it needs a little experimentation.
The basic principle is to set up one of the counters to operate in an "inverter" mode.· Adding a capacitor from the input of the inverter to ground in combination with a resistor (your skin) across the input and the output of the inverter you have a basic oscillator that varies in frequency depending on what the resistor·(or capacitor) value is.
From here, you just Zero the Phase accumulator for that counter, wait for a consistent time interval, and read the Phase accumulator.
Beau Schwabe
IC Layout Engineer
