Trying to figure out some problems (Dealing with "@" and passing var [Problem s
Ok, so I'm not as versed with the propeller as most are around here, that will be obvious.
Here is what I'm doing, and where my problems occur.
I have a binary file on a SD card, with some format0 midi music. The eeprom has a simple boot loader file.
When booting the main binary gets loaded the and prop is rebooted with the new code. So far so good (it works).
After the reboot, I am trying to read values from a csv into a byte array (these values will be for outputs from the midi music, more on this later). <---- this is not working
After this, the program loads a midi file from a DAT play list. <
this works
Then the program plays the file using Aribas midi player object. While playing the midi file audio, I have a cog that is turning on outputs to a PCF8575 chip.
Right now, I have a lookdown statement that works. If the note comes along that is in the lookdown statement, the output that corresponds to that number will turn on on the PCF8575 (I'm using LED's to know).
I worked for 18 hours yesterday to try and load a byte array with 16 values from a csv file. I have tried so many different versions of doing this I am absolutely confused.
I do not understand when and where the "@" symbol is used with a variable (besides cognew, and DAT). I have to say, I don't know, and really need someone to explain it in a way I'll remember.
Also, I would like to use the lookdown command (because it is fast), but I can't seem to get it to work with a byte array. This may be because it was designed to be used on expressions (not sure if that includes bytes).
Here is some of the code that I have hacked on. It is probably not right. I've changed it so much, I'm not sure what right is any more.
If I get this part right, then I need to move to the part wher I'm trying to look through these vars.
That is a chore, because culist[noparse][[/noparse]128] needs to be passed to a child object. BLAH!!!
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Post Edited (James Long) : 4/17/2009 8:11:33 AM GMT
this works
Pub loadScript | _r, _cursor, _cuect, _outnum, _midinote, _out
'' Load the script from the SD card
_cursor := @cueList ' Point at the cue list space -cuelist is the 128byte array
_r := sd.popen(@ScriptName, "r") ' and open the script file
if _r < 0 ' Check for successful open
disp.cls
disp.str(string("Config file fail!"))
waitcnt(clkfreq*3 + cnt)
abort ' and abort if it failed
disp.cls
disp.str(string("Loading Config!"))
'_cueCt := 0
repeat
_outnum := getnum ' Get the output number
_midinote := getnum ' Get the note from the file
bytemove(_cursor[noparse][[/noparse]_outnum],_midinote,1) ' Move the note into the word array
_cursor += 1 ' Move the cursor to the next values
_cueCt += 1
if _cueCt == maxScriptSize ' and be sure we don't overflow, should be 128
quit
elseif _cueCt > maxScriptSize
bigscript ' the array - if we do, tell the
abort ' user and abort
else
next
PRI getnum | n, num
'' Get a number or letter from the file
num := 0
repeat
n := sd.pgetc ' Get a character
if n < 0 ' Return -1 for end of file
abort
case n
13: quit ' LF and
44: quit ' comma end a number
48..57: num := num * 10 + n - 48 ' Handle a digit
65..76: num := 0 ' Map slat letters A thru L to 1 thru 12
return num
James L
James L
Partner/Designer
this means
LONG x
LONG AddressOfx
x:=1234
AddressOfx:=@x
where as "AddressOfx" points to some memery location
Ok, granted that makes sense.
When do you use the variable, and when do you use the address?
This is the major confusion.
James L
James L
Partner/Designer
As far as I know you use an address when you want to pass an array to a function.
Is that the only time??
I have seen code that confuses me in that respect.
Here is some code that confuses me.
PRI loadScript | _r, _cursor, _cuect, _cuenum, _delay, _bank, _slat, _cue, _desc1, _desc2 '' Load the script from the SD card _cursor := @cueList ' Point at the cue list space _r := sdfile.popen(@ScriptName, "r") ' and open the script file if _r < 0 ' Check for successful open abort ' and abort if it failed _cuect := 0 repeat ' Loop through the cues _cuenum := getnum ' Get the cue number wordmove(_cursor,@_cuenum,1) ' and save it in the cue list _delay := getnum ' Now get the delay wordmove(_cursor+2,@_delay,1) _bank := getnum ' Get the bank, _slat := getnum ' slat, _cue := getnum ' and cue and _r := (_bank << 8) + (_slat << 4) + _cue ' pack them into one word wordmove(_cursor+4,@_r,1) IF _bank == 7 ' Bank 7 indicates a MIDI file _r := getfn ' so read a filename ELSE ' Otherwise _desc1 := getnum ' Get the first description number _desc2 := getnum ' and the second and _r := (_desc1 << 8) + _desc2 ' and pack them into a word wordmove(_cursor+6,@_r,1) _cursor += 8 ' Move the cursor to the next cue if _cuenum == 0 ' The end of the script is indicated by quit ' a zero cue number _cuect += 1 ' Count the cues if _cueCt == maxScriptSize ' and be sure we don't overflow cuetracker.bigscript ' the array - if we do, tell the abort ' user and abort if cueList <> 9999 ' Warn the user if their script does cuetracker.nopause ' not start out paused cuetracker.cuectmsg(_cuect) ' and let them know we got it loadedThis code is to load a csv file from a SD card. I did not write this code, it is from a Propeller contest project. It evidently worked for the project.
Let me explain why this confuses me. Wordmove requires two addresses. I understand that _cursor is equal to @cueList. The problem I have with this code, how can _cursor be an array when it is a local variable of only a long? In the VAR section of the Object cuelist is huge.
Maybe I need to learn more about addresses and understanding them.
James L
James L
Partner/Designer
Post Edited (James Long) : 4/16/2009 7:13:24 PM GMT
the codeline
move only ONE word =16 bit
it copies the ADRESS of "_cuenum" (the RAM-ADDRESS where the array _cuenum BEGINS) to the variable "_cursor"
and an adress always fits into one long. This means "_cursor" contains just the RAM-ADRESS that POINTS to the begin of the array
The rest of the code I do not understand by reading it once or twice.
And it shows only a part of the program
what does getnum do in detail?
what does bigscript do in detail?
If I would program reading in a CSV-file I would start from scratch
by using the elementary commands to read single bytes from the SD-card to learn how
SD-card read and write works
best regards
Stefan
That's why in wordmove it reads _cursor and not @_cursor even if wordmove expects two adresses.
let's have a look at the hypotetical memory adresses of the byte array and it's content:
$1000 "H"
$1001 "e"
$1002 "l"
$1003 "p"
_cursor := @byte_array[noparse][[/noparse]0] ' so _cursor has the value $1000 and not "H"
wordmove( _cursor, @r, 1) would now be the same as wordmove( @byte_array[noparse][[/noparse]0] , @r, 1)
Pointers can be used the same way as the [noparse]/noparse inside of a function. If you have to pass an array to another function it wouldn't be a good idea to put the whole array on the stack. That's when pointers to are very helpful.
Stefan,
Thanks for the help,
Getnum uses the SD card access object to get characters from an SD file. The Pri method of the first post contains it's code. It gets a character one at a time, until it hits a comma, or a line feed.
Bigscript is just a method to display to the LCD that the file is too large. (we have received too much information).
James L
James L
Partner/Designer
So we use addresses to move things around and tell other parts of the Spin program where to find the data. But when actually working with the data, we must use the actual var, not it's address. So, I think where I was getting to confused is between the byte and where the byte is located.
So by your example.
_cursor := @byte_array[noparse][[/noparse]0] 'would make cursor a value of $1000 <---- we use this to pass out to other methods and objects for them to know where the values are
_cursor := byte_array[noparse][[/noparse]0] 'would make cursor a value of "H" <---- we use this when the other object/method wants to use the data contained within.
I see the difference and now I think I can remember that.
Let me see if I can rewrite the code to reflect what you have stated.
EDITED slightly to help other people understand if they do not.
James L
James L
Partner/Designer
Post Edited (James Long) : 4/16/2009 8:11:34 PM GMT
1. If you have an array it would be a waste of stack to put all elements of the array to the stack in a function call -> using a pointer helps
2. If you call functions of another object this object does not know any of your variables -> using a pointer is the only way to let the object access your variables
For some reason I don't think I have everything totally correct.
I think I'm getting closer, but still, not sure where the problem lies.
I'm going to attach the code that is relevant. I would attach the total code, but it is huge, and clanky to go through. I have a lot of cleaning to do of items I'm not using.
James L
James L
Partner/Designer
The above is where the new cog is called. "lighout" is the following:
PUB Start(cueListaddr) | Out IO.set_Pins(6,5) Out:= %0000_0000_0000_0000 IO.Initialize IO.OUT(ADDR,Out) cognew(main(@ledstate, @note, cueListaddr), @ledaddr) PUB main(ledstateaddr, noteaddr, cueListaddr) Noteout := getled(note, cueListaddr) 'Noteout := note if Noteout == 0 return If ledstate == $90 noteout -= 1 LED|= |< noteout IO.OUT(ADDR,LED) else noteout -= 1 LED&= !|< noteout IO.OUT(ADDR,LED) noteout~ PUB GETLED(Value, cueListaddr)| GETLEDS, revalue 'GETLEDS := lookdown(Value: 74, 73, 72, 70, 69, 68, 67, 65, 51, 53, 56, 58, 60, 61, 62, 63) GETLEDS := lookdown(Value: cueListaddr, cueListaddr, cueListaddr, cueListaddr, cueListaddr, cueListad -----code clipped for sanity----) {repeat GETLEDS from 1 to 128 if value == cuelistaddr[noparse][[/noparse]getleds] revalue := getleds return revalue quit else next}Notice I have some items disabled, for testing purposes. Mostly in the last method.
synth.noteOn(d1,ch,d2) 'Note On 'nout := GETLED(d1) lightout.main($90,d1,@cuelist)The above are the calling routines to the lighout cog.
I'm so confused.
James L
James L
Partner/Designer
Post Edited (James Long) : 4/16/2009 9:45:12 PM GMT
Depending on the type you have to use
... byte[noparse][[/noparse] cueListaddr ], byte[noparse][[/noparse] cueListaddr ][noparse][[/noparse]7], byte[noparse][[/noparse] cueListaddr ][noparse][[/noparse]8]....
... word[noparse][[/noparse] cueListaddr ], word[noparse][[/noparse] cueListaddr ][noparse][[/noparse]7], word[noparse][[/noparse] cueListaddr ][noparse][[/noparse]8] ...
or ... long[noparse][[/noparse] cueListaddr ], long[noparse][[/noparse] cueListaddr ][noparse][[/noparse]7], long[noparse][[/noparse] cueListaddr ][noparse][[/noparse]8] ...
byte[noparse]/noparse, word[noparse]/noparse and long[noparse]/noparse in the code section allows you to access any byte, word or long in HUB memory. This is how you can access the value that a pointer points to.
The [noparse]/noparse addresses are in the code, not sure why they don't show.
But you are right, I do want to address the information contained in the address.
I didn't think about the "byte" command.
I'll try that next.
Am I even passing the parameter right? For some reason I always get confused of how to pass parameters.
James L
James L
Partner/Designer
Add a postfix _addr to the variable name if it is a pointer. Then you simply need to know what the function expects - the real value or an adress.
If the function wants a pointer, you have to pass @var1 or var1_addr.
If the function wants a real value, you have to pass var1 or byte[noparse][[/noparse] var1_addr ] or in case of an byte array byte[noparse][[/noparse] var1_addr ][noparse][[/noparse] index ]
Ok, so I have added in byte[noparse][[/noparse]cuelist_addr][noparse][[/noparse]x] into the lookdown (changed them all to reflect this)
Still not sure what is happening.
I think my newcog calls and method calls passing the parameter are wrong.
James L
On a secondary note, do you accept checks for tutoring service?
James L
Partner/Designer
In the manual, it states Lookdown uses "Expressions". I wonder if anyone could define that in this instance.
James L
James L
Partner/Designer
I finally got the call to work. Not the way I wanted to, but still, it works.
the part which gave the trouble follows:
repeat _outnum := getnum ' Get the output number _midinote := getnum ' Get the note from the file bytemove(_cursor,@_midinote,1) ' Move the note into the word array _cursor += 1 ' Move the cursor to the next valuesI was trying to use _outnum to set the index of _cursor (ie. _cursor[noparse][[/noparse]_outnum] or _cursor[noparse][[/noparse]@_outnum] ). I never got a successful result from doing this. I'm not sure what I was doing wrong, but the method above works the same (well somewhat).
I appreciate the help, and if any of you need any pcb assembly, let me know.
James L
James L
Partner/Designer
