Weired results with Serial_Lcd
OK, I'm stumped. I just got my First propeller today and I'm slowly grasping the propeller language. But when I try to link to a Parallax 4x20 serial lcd, using the Serial_LCD Object from the Object Exchange, I get weird results. Text doesn't show up as expected. Well here's the simple test code I'm try to use.
The display seems to respond to function commands. But, the text never shows up in the right place. Its shifted off the left egde when it actualy shows up and isn't Smile.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ LCD : "Serial_Lcd" PUB main WAITCNT(clkfreq / 10 + cnt) LCD.init(9,9600,4) LCD.cursor(1) LCD.cls LCD.backLight(true) LCD.str(str1) waitcnt(clkfreq * 5 + cnt) DAT str1 byte "Proto Prop Rocks",13,0
you have to call the command LCD.str like this
the "@" in this use is called the adress-operator
If you get strange results from something it's always worth a look into the definition of the code
the method str in the file serial_Lcd.spin
"strAdr means string ADRESS (=location in memory where the string is stored)
to narrow down problems like this
try variations like this
best regards
Stefan
