Parallax oscope software glitch?
It looks like there is a glitch either in soft of in the hardware of the scope. Say, i have 5V DC on the scope input. The scope shows it correctly in the 5, 2 and 1V ranges, but below that the reading suddenly jumps to about 2V. This happens on both channels, and i have newer version of the software (I'm not sure, but i believe it was the same with the old version).
Did anyone notice such thing before. Or it's a glitch of my scope only?
Thank you
Rita
Thank you
Rita
What operating system are You using?
I have had some problems with Vista and XP 64 on a few software applications. the Parallax Oscope is just one of them.
I haven't had any voltage reading problems.
One last thing. If Your using the Parallax Oscope with a laptop, Some times the power out to the USB port will be limited if on battery or if battery was low when hooked up to the charger.
Sorry I can't give a definite answer.
__________$WMc%________
The Truth is out there············································ BoogerWoods, FL. USA
I'm pretty sure the truth is somewhere here on this forum [noparse];)[/noparse].
The Scope does use a different internal op-amp for different ranges depending on the current setting. As I recall from 1V up it uses one and below 1V uses another. However I don’t recall such an issue being reported previously. I will contact our Tech Support Dept. and have them test both versions of the software to see if they can duplicate what you’re seeing. Take care.
Chris Savage
Parallax Engineering
My Parallax Oscope runs flawlessly on My XPhome32bit machine(tower) and on My XPpro32bit laptop.
It was the best $130 bucks I spent in a long time on a tool ,I use it all the time.
Its XP64 and Vista(64bit) that I've had problems with USB drivers.
________$WMc%__________
Rita
maybe you can find this out through your tech support as well?
Thank you
Rita
Chris Savage
