IR Modulation
                    I have a question about a modulated IR Detector. I built the circuit below, which uses a 555 timer to modulate 2 IR LEDs to 40kHz. Now at the same time, I need to be able to check that it truly is modulated, right? I though, since there was a fairly easy way of modulating the IR light, there probabl is a an easy way of making an IR Detector only look for a modulated signal. I have not been able to find anything. All the circuits i find use a sharp, or panasonic modulated (38 - 40kHz) IR·detector. Does anyone know of where to find a circuit to use a standard IR detector, such as an SFH506, to filter out everything but the modulated signal.
The reason I ask is I can of course recieve the modulated signal with this detector, but, light effects it, and if anyone tries to turn on the tv within 10 feet I detect that too. I have searched through the stores around me for one of the Sharp or Panasonic modulated detectors, but no luck. So, i figure I would try and see if it can be done using something else, before I spend $10 shipping for the one part.
-Mike
······ I'll try everything once [noparse]:)[/noparse]
-Mike
kind of like this: http://faculty.kc.devry.edu/twheeler/eet368/lab5.pdf
Manetheren
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
