Encoder Issues
I've been trying to get readings from my quadrature encoder. Just incase: It is a US Digital E3-200.
I am constructing a motor controller and I have all the code working except for the encoder object.
Here is the code I'm using to test it:
VAR
long pos
CON
_xinfreq = 5_000_000
_clkmode = xtal1 + pll16x
OBJ
serial : "FullDuplexSerial"
Encoder: "Quadrature Encoder"
PUB Main
serial.start(0,1,0,38400)
Encoder.start(4,2,0,@pos)
repeat
waitcnt(cnt+8_000_000)
serial.hex(pos[noparse][[/noparse]0],4)
serial.tx(" ")
My output can vary between 0x0000 and 0xFFFF or 0x0000 and 0x0001 depending where the wheel is when I start.
I'm using just the basic Encoder object and I have two channel encoders. Is there something I'm doing wrong?
VAR
long pos
CON
OBJ
PUB Main
repeat
serial.tx(" ")
Is the encoder object you're using from the Object Exchange?
"They may have computers, and other weapons of mass destruction." - Janet Reno
A nit waitcnt(cnt+8_000_000) is usually coded as waitcnt(8_000_000 + cnt)
John Abshier
Is there a hidden secret in the waitcnt-implementation? I can't see a difference! Adding is commutative, so the result is the same for A + B and B + A.
http://forums.parallax.com/showthread.php?p=720621
Richard in Michigan
Normally one writes waitcnt(ticks + cnt) so that cnt is the last value fetched before the waitcnt pasm instruction executes.
It is possible for a program to appear to hang on the order of a few minutes if CNT has passed before waitcnt happens.
For small values of "ticks" there is risk in hanging the program anyway ... best to be aware of this potential problem.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
plus is commutative but the systemconter is running free at a very high speed
increments every 12.5 nanosecond
if you code
waitcnt(cnt + 2_000_000)
then the actual cnt-value will be a lot of ticks ahead when the PASM-waitcnt of the interpreter gets executed
(the interpreter needed some 100 ticks to execute the "+"
if you code
waitcnt(2_000_000 + cnt) the ticks lost until executing the PASM-waitcnt is minimized and still it has to be above
waitcnt(381 + cnt) the ticks lost until executing the PASM-waitcnt is minimized and still it has to be above
as it takes 382 ticks to finish the "+" of 381 and cnt
so with
waitcnt(379 + cnt) the actual value of cnt will be already OVER the result of 379 + cnt and then the next time
the cnt-value matches is 2 ticks away (which is around 53 seconds at a 80 MHz clock
if you code
if you code
so with
the cnt-value matches, is 2^32 = 4.294.967.296 ticks away (which is around 53 seconds at a 80 MHz clock
best regards
Stefan
