Christmas All Year Long
John Abshier
Remember, as a child, the anticipation leading up to Christmas.· Parallax gives us Christmas all year long.· Well, at least the anticipation.· New products seen in various locals and waiting to go on sale.· I for one am waiting for the mid-sized robot, linear array daughterboard, Propscope, laser rangefinder, and, the number one toy, the Prop II.
John Abshier
John Abshier
I can address the linear array daughterboard. My assembler accidently soldered 900 of them using leaded solder (!) and had to start over with fresh PCBs and fresh SMT parts. So things got a little delayed. I hope to see assembled boards in another couple weeks. Then they have to be tested and packaged.
This seems like the project without end sometimes. Thanks for your patience!
Ouch, that hurts. Whooops!
I would hate to be required to warranty that.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
I'm sure they are not happy with the mix up.
One reason we only do RoHS, unless someone really gives a good reason as to why not.
Maybe one day we will start through hole parts. We have discussed the possibility, just need more work before we start spending more money.
James L
James L
Partner/Designer
That is worse. I could probably have handled a mix up with a previous customer, but making a big mistake like that with a new customer would be devastating.
But I have to admit, mistakes do happen. We have made them as well, just not that big.
James L
James L
Partner/Designer
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
I do agree there have been studies done on lead-free solder. There is no doubt that items will not last as long, but with technology changing as fast as it does, it is not much of a problem. Most items are not around long enough for the problem to show. Also most of the problems are shown to appear faster if the assembly temperature was incorrect.
But remember, by 2014, there will only be lead-free, so you should get used to it. That is only 5 years away.
There is no doubt that leaded solder works better, but it is dangerous to work with, can be hazardous to dispose of.
I just try to deal with the fact. Not much I can do to change it.
James L
James L
Partner/Designer
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
