Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Relays for Basic Stamp — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
Joe33
8
2009-04-14 18:26
edited 2009-04-14 22:49
in
BASIC Stamp
I need a relay that I can drive from a Basic Stamp 2 and switch to 12V DC power.
Does anybody know where I can find one?
MtnFlyer
28
2009-04-14 18:30
edited 2009-04-14 18:30
You might try
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=1049447&keywords=power relays
And look for relays that operate on the voltage of the Basic Stamp 2 output and can handle the current at 12VDC that you want.
Mike2545
433
2009-04-14 18:30
You can check out this web site
www.allelectronics.com/make-a-store/item/RLY-625/5VDC-DPDT-DIP-RELAY/-/1.html
You will need to drive it with a transistor.
Mike2545
This message sent to you on 100% recycled electrons.
Joe33
8
2009-04-14 19:08
edited 2009-04-14 19:08
Thanks [noparse]:)[/noparse]
Wolfbrother
129
2009-04-14 22:49
I have used Crydom's DO061A with good success directly from the stamp output, it only takes 15mA at the Stamps voltage and can switch up to 60VDC at 1A. Here's the datasheet
http://www.crydom.com/en/Products/Catalog/d_o.pdf
Sign In
Register
to comment.
Mike2545
