"Large" data arrays
Stupid question I suspect but how can I lay out 2KB or 8KB data?
I want to load up monitor prog and will want to set out the running progs but I innocentle tried to put it in Dat sections and got a bunch of errors.
Do I really have to put every single line as a separate label??
no you don't need to set new labels just set a new LINE without a new label but again with
the memorysize byte, word or long
you can do this
rx_buffer long 0, 0, 0, 0, 0, 0, 0, 0 '32 bytes long 0, 0, 0, 0, 0, 0, 0, 0 '32 bytes long 0, 0, 0, 0, 0, 0, 0, 0 '32 bytes long 0, 0, 0, 0, 0, 0, 0, 0 '32 bytes tx_buffer long 0, 0, 0, 0, 0, 0, 0, 0 '32 bytes long 0, 0, 0, 0, 0, 0, 0, 0 '32 bytes long 0, 0, 0, 0, 0, 0, 0, 0 '32 bytes long 0, 0, 0, 0, 0, 0, 0, 0 '32 bytesand this can be done to what ever size you want to as long as memory is not exceeded
best regards
Stefan
I tried that but got errors, or at least I thought I did! something else to hunt for now.
This reserves 64 longs in hub ram and sets them to zero.
