BS2 to Prop
I have been playing with a new serial device that requires me to initialize the unit prior to receiving data.· After numerous attempts on the Prop I moved back to my comfort zone (STAMP) and was able to initialize the device and start monitoring the output.
Below is the Stamp that works
Here is the SPIN code that I have been using without results.
I do have the standard 5vDC protection in place for the the Prop I/O and I have checked and rechecked the connections but I can not get the Prop to initialize the serial device.· It is possible that the 3.3v output signal is not detectable on the serial device and that is my problem.· I have not heard back from the manufacturer yet on that question.
Can someone·tell me if I am doing something wrong with the SPIN code?·
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
' {$STAMP BS2px}
' {$PBASIC 2.5}
PNI_RX CON 1
PNI_TX CON 0
N9600 CON 16780
char VAR Byte
PAUSE 250
Main:
SEROUT PNI_TX, N9600, [noparse][[/noparse]$00,$05,$15,$BD,$61]
PAUSE 100
start:
SERIN PNI_RX, N9600, [noparse][[/noparse]char]
DEBUG HEX char
GOTO start
con
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
obj
debug[noparse][[/noparse]2]: "FullDuplexSerialPlus" 'Debug object
var
byte pni
pub main
Debug[noparse][[/noparse]0].start(31, 30, 0, 9600) 'Start the debug terminal
debug[noparse][[/noparse]0].str(string("Starting"))
debug[noparse][[/noparse]1].start(16,17,0,9600)
waitcnt(clkfreq/4 + cnt)
debug[noparse][[/noparse]1].tx($00)
debug[noparse][[/noparse]1].tx($05)
debug[noparse][[/noparse]1].tx($15)
debug[noparse][[/noparse]1].tx($BD)
debug[noparse][[/noparse]1].tx($61)
repeat
debug[noparse][[/noparse]0].hex(debug[noparse][[/noparse]1].rx,1) 'Receive btye and display
WWW.HAPB.NET
John Abshier
' {$STAMP BS2px} ' {$PBASIC 2.5} PNI_RX CON 1 PNI_TX CON 0 N9600 CON 16780 char VAR Byte idx VAR Byte value VAR Word value2 VAR Byte PAUSE 250 Main: SEROUT PNI_TX, N9600, [noparse][[/noparse]$00,$0A,$03,$04,$05,$07,$18,$19,$84,$BF] 'heading, temp, pitch, roll PAUSE 100 SEROUT PNI_TX, N9600, [noparse][[/noparse]$0,$5,$15,$BD,$61] 'KStartIntervalMode PAUSE 250 start: SERIN PNI_RX, N9600, [noparse][[/noparse]WAIT($0,$1A,$5,$4),SPSTR 24] idx = 0 DO GET idx, char DEBUG IHEX char idx = idx + 1 LOOP UNTIL idx = 24 GOTO start '5 Sample outputs 'preample Heading Temperature Pitch Roll '$0$1A$5$4 $5 $42$CF$B7$B1 $7 $41$E7$C0$0 $18 $C0$44$7B$85 $19 $40$29$A0$D7 '$0$1A$5$4 $5 $42$CF$83$85 $7 $41$E8$40$0 $18 $C0$44$79$7E $19 $40$29$9A$79 '$0$1A$5$4 $5 $42$CF$9C$3B $7 $41$E7$80$0 $18 $C0$44$99$BB $19 $40$29$90$8F '$0$1A$5$4 $5 $42$CF$80$9D $7 $41$E8$0$0 $18 $C0$44$31$B7 $19 $40$29$D5$19 '$0$1A$5$4 $5 $42$CF$AD$24 $7 $41$E7$C0$0 $18 $C0$44$97$38 $19 $40$29$68$1A9The output has been verified to be correct but when I listen in with the Prop I get a completely different and incorrect output.· This is a seperate issue from being able to TX to the device.
con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 obj debug[noparse][[/noparse]2]: "FullDuplexSerialPlus" 'Debug object pub main Debug[noparse][[/noparse]0].start(31, 30, 0, 9600) 'Start the debug terminal debug[noparse][[/noparse]0].str(string("Starting")) debug[noparse][[/noparse]1].start(16,17,0,9600) repeat debug[noparse][[/noparse]0].hex(debug[noparse][[/noparse]1].rx,1) 'Receive btye and display '5 Sample outputs '0CB5759D93E31ADD1F751D5FE9D0 '00B5759D3DF35ABD131D2D5FE590 '00B5759D3DF35ABD131D2D5FE590 '00B5759D51F3D6641F951D5FE970 '0FB5759D1FF3926417D31D3FFD30Any ideas why that might be the case?
I added a side-by-side output image.· It is interesting how the STAMP is clean and the Prop output is all zeros between data burst and they do not come close to matching(besides the $ I have the stamp producing in the output)
WWW.HAPB.NET
Post Edited (Earl Foster) : 4/12/2009 12:58:36 AM GMT
your codeline
debug[noparse][[/noparse]0].hex(debug.rx,1) 'Receive byte and displaysend only ONE digit. one byte are TWO hexadecimal digits
so change it to
debug[noparse][[/noparse]0].hex(debug.rx,2) 'Receive byte and displayIf this does not help
Post a picture of how you have connected your device to the propeller.
What voltagelevels does the device have for low and high ?
Did you check your propeller-setup with a terminalsoftware.
I mean a terminalsoftware that is known to send proper data connected to the propeller on object debug
receiving data from the terminalsoftware
sending a $00 watch what the propeller receives
sending a $FF watch what the propeller receives
sending a $01 watch what the propeller receives
sending a $FE watch what the propeller receives
sending a $02 watch what the propeller receives
sending a $FD watch what the propeller receives
best regards
Stefan
I am facing one of two issues.· Either my code is incorrect or the device needs 5v signal.· I have experimented with both, but troubleshooting 2 issues is not the way to go. Need to eliminate one before moving on to the other.
Hence my question
I need to send, in·HEX, the·following·PUSH command frame 000515BD61 where
··· 00 05· - Int16 which is the byte count including CRC
··· 15····· -·UInt8 packet frame id (start pushing data command)
··· BD 61· - UInt16 is CRC-CCITT (XModem)
Would the code below·correctly send 000515BD61 to the device?·
I have also tried droping the leading zeros resulting in 0515BD61 with no results.
con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 obj debug[noparse][[/noparse]2]: "FullDuplexSerialPlus" pub main Debug[noparse][[/noparse]0].start(31, 30, 0, 9600) debug[noparse][[/noparse]0].str(string("Starting")) waitcnt(clkfreq + cnt) debug[noparse][[/noparse]1].start(1,0,1,9600) debug[noparse][[/noparse]1].tx($00) debug[noparse][[/noparse]1].tx($05) debug[noparse][[/noparse]1].tx($15) debug[noparse][[/noparse]1].tx($BD) debug[noparse][[/noparse]1].tx($61) repeat debug[noparse][[/noparse]0].hex(debug[noparse][[/noparse]1].rx,2) 'Receive btye and display▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
WWW.HAPB.NET
Any suggestions?
WWW.HAPB.NET
I could use some suggestion and ideas of what the problem could be.· The stamp program has no problem getting the PNI device to transmit data.· AH - let me look at the Stamp waveform and compare them.· The attached plots are the waveform of the push command sent to the PNI device.
WWW.HAPB.NET
Post Edited (Earl Foster) : 4/13/2009 2:14:04 PM GMT
So I need to invert the TX signal from the Prop.· Hopefully that will take care of the problem.
WWW.HAPB.NET
WWW.HAPB.NET
