How many Case can we use?
How many Case statements can we use? see exampleI have not seen it written in the manual so I am asking the general public. I assume 32, but before I write my complex library I wish to know.
[b] Pri comp(In) : Out Case IN 1: 2: 3: 4: 5.....32? [/b]
I found following limits:
1) in a PUB/PRI object there are max 63 select CASE statements
2) in a object file there are max 254 PUB or PRI objects
Regards
Gianni
Post Edited (Giemme) : 4/12/2009 6:17:48 AM GMT
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
http://forums.parallax.com/forums/default.aspx?f=25&m=289079&g=289214#m289214
Regards
Gianni
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long i OBJ Debug: "FullDuplexSerialPlus" PUB TestCase Debug.start(31, 30, 0, 115200) repeat i from 0 to 650 case i 1: debug.str(string("no 1")) 2: debug.str(string("no 2")) 3: debug.str(string("no 3")) 4: debug.str(string("no 4")) 5: debug.str(string("no 5")) 6: debug.str(string("no 6")) 7: debug.str(string("no 7")) 8: debug.str(string("no 8")) 9: debug.str(string("no 9")) 10: debug.str(string("no 10")) 11: debug.str(string("no 11")) 12: debug.str(string("no 12")) 13: debug.str(string("no 13")) 14: debug.str(string("no 14")) 15: debug.str(string("no 15")) 16: debug.str(string("no 16")) 17: debug.str(string("no 17")) 18: debug.str(string("no 18")) 19: debug.str(string("no 19")) 20: debug.str(string("no 20")) 21: debug.str(string("no 21")) 22: debug.str(string("no 22")) 23: debug.str(string("no 23")) 24: debug.str(string("no 24")) 25: debug.str(string("no 25")) 26: debug.str(string("no 26")) 27: debug.str(string("no 27")) 28: debug.str(string("no 28")) 29: debug.str(string("no 29")) 30: debug.str(string("no 30")) 31: debug.str(string("no 31")) 32: debug.str(string("no 32")) 33: debug.str(string("no 33")) 34: debug.str(string("no 34")) 35: debug.str(string("no 35")) 36: debug.str(string("no 36")) 37: debug.str(string("no 37")) 38: debug.str(string("no 38")) 39: debug.str(string("no 39")) 40: debug.str(string("no 40")) 41: debug.str(string("no 41")) 42: debug.str(string("no 42")) 43: debug.str(string("no 43")) 44: debug.str(string("no 44")) 45: debug.str(string("no 45")) 46: debug.str(string("no 46")) 47: debug.str(string("no 47")) 48: debug.str(string("no 48")) 49: debug.str(string("no 49")) 50: debug.str(string("no 50")) 51: debug.str(string("no 51")) 52: debug.str(string("no 52")) 53: debug.str(string("no 53")) 54: debug.str(string("no 54")) 55: debug.str(string("no 55")) 56: debug.str(string("no 56")) 57: debug.str(string("no 57")) 58: debug.str(string("no 58")) 59: debug.str(string("no 59")) 60: debug.str(string("no 60")) 61: debug.str(string("no 61")) 62: debug.str(string("no 62")) 63: debug.str(string("no 63")) 64: debug.str(string("no 64")) other: case i 65: debug.str(string("no 65")) 66: debug.str(string("no 66")) 67: debug.str(string("no 67")) 68: debug.str(string("no 68")) 69: debug.str(string("no 69")) 70: debug.str(string("no 70")) 71: debug.str(string("no 71")) 72: debug.str(string("no 72")) 73: debug.str(string("no 73")) 74: debug.str(string("no 74")) 75: debug.str(string("no 75")) 76: debug.str(string("no 76")) 77: debug.str(string("no 77")) 78: debug.str(string("no 78")) 79: debug.str(string("no 79")) 80: debug.str(string("no 80")) 81: debug.str(string("no 81")) 82: debug.str(string("no 82")) 83: debug.str(string("no 83")) 84: debug.str(string("no 84")) 85: debug.str(string("no 85")) 86: debug.str(string("no 86")) 87: debug.str(string("no 87")) 88: debug.str(string("no 88")) 89: debug.str(string("no 89")) 90: debug.str(string("no 90")) 91: debug.str(string("no 91")) 92: debug.str(string("no 92")) 93: debug.str(string("no 93")) 94: debug.str(string("no 94")) 95: debug.str(string("no 95")) 96: debug.str(string("no 96")) 97: debug.str(string("no 97")) 98: debug.str(string("no 98")) 99: debug.str(string("no 99")) 100: debug.str(string("no 100")) 101: debug.str(string("no 101")) 102: debug.str(string("no 102")) 103: debug.str(string("no 103")) 104: debug.str(string("no 104")) 105: debug.str(string("no 105")) 106: debug.str(string("no 106")) 107: debug.str(string("no 107")) 108: debug.str(string("no 108")) 109: debug.str(string("no 109")) 110: debug.str(string("no 110")) 111: debug.str(string("no 111")) 112: debug.str(string("no 112")) 113: debug.str(string("no 113")) 114: debug.str(string("no 114")) 115: debug.str(string("no 115")) 116: debug.str(string("no 116")) 117: debug.str(string("no 117")) 118: debug.str(string("no 118")) 119: debug.str(string("no 119")) 120: debug.str(string("no 120")) 121: debug.str(string("no 121")) 122: debug.str(string("no 122")) 123: debug.str(string("no 123")) 124: debug.str(string("no 124")) 125: debug.str(string("no 125")) 126: debug.str(string("no 126")) 127: debug.str(string("no 127")) 128: debug.str(string("no 128")) other: case i 129: debug.str(string("no 129")) 130: debug.str(string("no 130")) 131: debug.str(string("no 131")) 132: debug.str(string("no 132")) 133: debug.str(string("no 133")) 134: debug.str(string("no 134")) 135: debug.str(string("no 135")) 136: debug.str(string("no 136")) 137: debug.str(string("no 137")) 138: debug.str(string("no 138")) 139: debug.str(string("no 139")) 140: debug.str(string("no 140")) 141: debug.str(string("no 141")) 142: debug.str(string("no 142")) 143: debug.str(string("no 143")) 144: debug.str(string("no 144")) 145: debug.str(string("no 145")) 146: debug.str(string("no 146")) 147: debug.str(string("no 147")) 148: debug.str(string("no 148")) 149: debug.str(string("no 149")) 150: debug.str(string("no 150")) 151: debug.str(string("no 151")) 152: debug.str(string("no 152")) 153: debug.str(string("no 153")) 154: debug.str(string("no 154")) 155: debug.str(string("no 155")) 156: debug.str(string("no 156")) 157: debug.str(string("no 157")) 158: debug.str(string("no 158")) 159: debug.str(string("no 159")) 160: debug.str(string("no 160")) 161: debug.str(string("no 161")) 162: debug.str(string("no 162")) 163: debug.str(string("no 163")) 164: debug.str(string("no 164")) 165: debug.str(string("no 165")) 166: debug.str(string("no 166")) 167: debug.str(string("no 167")) 168: debug.str(string("no 168")) 169: debug.str(string("no 169")) 170: debug.str(string("no 170")) 171: debug.str(string("no 171")) 172: debug.str(string("no 172")) 173: debug.str(string("no 173")) 174: debug.str(string("no 174")) 175: debug.str(string("no 175")) 176: debug.str(string("no 176")) 177: debug.str(string("no 177")) 178: debug.str(string("no 178")) 179: debug.str(string("no 179")) 180: debug.str(string("no 180")) 181: debug.str(string("no 181")) 182: debug.str(string("no 182")) 183: debug.str(string("no 183")) 184: debug.str(string("no 184")) 185: debug.str(string("no 185")) 186: debug.str(string("no 186")) 187: debug.str(string("no 187")) 188: debug.str(string("no 188")) 189: debug.str(string("no 189")) 190: debug.str(string("no 190")) 191: debug.str(string("no 191")) 192: debug.str(string("no 192")) 'if you would do another "other" 'here you would get an errormessage blocknest stackoverflow 'other: debug.str(string("no 191")) 'case i '191: debug.str(string("no 191")) 'but why not using several case statements after each other like here 'or if you need only different values to use the command "lookup" case i 193: debug.str(string("no 193")) 194: debug.str(string("no 194")) 195: debug.str(string("no 195")) 196: debug.str(string("no 196")) 197: debug.str(string("no 197")) 198: debug.str(string("no 198")) 199: debug.str(string("no 199")) 200: debug.str(string("no 200")) 201: debug.str(string("no 201")) 202: debug.str(string("no 202")) 203: debug.str(string("no 203")) 204: debug.str(string("no 204")) 205: debug.str(string("no 205")) 206: debug.str(string("no 206")) 207: debug.str(string("no 207")) 208: debug.str(string("no 208")) 209: debug.str(string("no 209")) 210: debug.str(string("no 210")) 211: debug.str(string("no 211")) 212: debug.str(string("no 212")) 213: debug.str(string("no 213")) 214: debug.str(string("no 214")) 215: debug.str(string("no 215")) 216: debug.str(string("no 216")) 217: debug.str(string("no 217")) 218: debug.str(string("no 218")) 219: debug.str(string("no 219")) 220: debug.str(string("no 220")) 221: debug.str(string("no 221")) 222: debug.str(string("no 222")) 223: debug.str(string("no 223")) 224: debug.str(string("no 224")) 225: debug.str(string("no 225")) 226: debug.str(string("no 226")) 227: debug.str(string("no 227")) 228: debug.str(string("no 228")) 229: debug.str(string("no 229")) 230: debug.str(string("no 230")) 231: debug.str(string("no 231")) 232: debug.str(string("no 232")) 233: debug.str(string("no 233")) 234: debug.str(string("no 234")) 235: debug.str(string("no 235")) 236: debug.str(string("no 236")) 237: debug.str(string("no 237")) 238: debug.str(string("no 238")) 239: debug.str(string("no 239")) 240: debug.str(string("no 240")) 241: debug.str(string("no 241")) 242: debug.str(string("no 242")) 243: debug.str(string("no 243")) 244: debug.str(string("no 244")) 245: debug.str(string("no 245")) 246: debug.str(string("no 246")) 247: debug.str(string("no 247")) 248: debug.str(string("no 248")) 249: debug.str(string("no 249")) 250: debug.str(string("no 250")) 251: debug.str(string("no 251")) 252: debug.str(string("no 252")) 253: debug.str(string("no 253")) 254: debug.str(string("no 254")) 255: debug.str(string("no 255")) 256: debug.str(string("no 255")) 'another limit are 256 string-constants (0-255) 'debug.str(string("no 257")) 'error too many string constantsbest regards
Stefan
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long i OBJ Debug: "FullDuplexSerialPlus" PUB TestCase Debug.start(31, 30, 0, 115200) repeat i from 1 to 256 case i 1: debug.str(string("no 1")) 2: debug.str(string("no 2")) 3: debug.str(string("no 3")) 4: debug.str(string("no 4")) 5: debug.str(string("no 5")) 6: debug.str(string("no 6")) 7: debug.str(string("no 7")) 8: debug.str(string("no 8")) 9: debug.str(string("no 9")) 10: debug.str(string("no 10")) 11: debug.str(string("no 11")) 12: debug.str(string("no 12")) 13: debug.str(string("no 13")) 14: debug.str(string("no 14")) 15: debug.str(string("no 15")) 16: debug.str(string("no 16")) 17: debug.str(string("no 17")) 18: debug.str(string("no 18")) 19: debug.str(string("no 19")) 20: debug.str(string("no 20")) 21: debug.str(string("no 21")) 22: debug.str(string("no 22")) 23: debug.str(string("no 23")) 24: debug.str(string("no 24")) 25: debug.str(string("no 25")) 26: debug.str(string("no 26")) 27: debug.str(string("no 27")) 28: debug.str(string("no 28")) 29: debug.str(string("no 29")) 30: debug.str(string("no 30")) 31: debug.str(string("no 31")) 32: debug.str(string("no 32")) 33: debug.str(string("no 33")) 34: debug.str(string("no 34")) 35: debug.str(string("no 35")) 36: debug.str(string("no 36")) 37: debug.str(string("no 37")) 38: debug.str(string("no 38")) 39: debug.str(string("no 39")) 40: debug.str(string("no 40")) 41: debug.str(string("no 41")) 42: debug.str(string("no 42")) 43: debug.str(string("no 43")) 44: debug.str(string("no 44")) 45: debug.str(string("no 45")) 46: debug.str(string("no 46")) 47: debug.str(string("no 47")) 48: debug.str(string("no 48")) 49: debug.str(string("no 49")) 50: debug.str(string("no 50")) 51: debug.str(string("no 51")) 52: debug.str(string("no 52")) 53: debug.str(string("no 53")) 54: debug.str(string("no 54")) 55: debug.str(string("no 55")) 56: debug.str(string("no 56")) 57: debug.str(string("no 57")) 58: debug.str(string("no 58")) 59: debug.str(string("no 59")) 60: debug.str(string("no 60")) 61: debug.str(string("no 61")) 62: debug.str(string("no 62")) 63: debug.str(string("no 63")) 64: debug.str(string("no 64")) other: case i 65: debug.str(string("no 65")) 66: debug.str(string("no 66")) 67: debug.str(string("no 67")) 68: debug.str(string("no 68")) 69: debug.str(string("no 69")) 70: debug.str(string("no 70")) 71: debug.str(string("no 71")) 72: debug.str(string("no 72")) 73: debug.str(string("no 73")) 74: debug.str(string("no 74")) 75: debug.str(string("no 75")) 76: debug.str(string("no 76")) 77: debug.str(string("no 77")) 78: debug.str(string("no 78")) 79: debug.str(string("no 79")) 80: debug.str(string("no 80")) 81: debug.str(string("no 81")) 82: debug.str(string("no 82")) 83: debug.str(string("no 83")) 84: debug.str(string("no 84")) 85: debug.str(string("no 85")) 86: debug.str(string("no 86")) 87: debug.str(string("no 87")) 88: debug.str(string("no 88")) 89: debug.str(string("no 89")) 90: debug.str(string("no 90")) 91: debug.str(string("no 91")) 92: debug.str(string("no 92")) 93: debug.str(string("no 93")) 94: debug.str(string("no 94")) 95: debug.str(string("no 95")) 96: debug.str(string("no 96")) 97: debug.str(string("no 97")) 98: debug.str(string("no 98")) 99: debug.str(string("no 99")) 100: debug.str(string("no 100")) 101: debug.str(string("no 101")) 102: debug.str(string("no 102")) 103: debug.str(string("no 103")) 104: debug.str(string("no 104")) 105: debug.str(string("no 105")) 106: debug.str(string("no 106")) 107: debug.str(string("no 107")) 108: debug.str(string("no 108")) 109: debug.str(string("no 109")) 110: debug.str(string("no 110")) 111: debug.str(string("no 111")) 112: debug.str(string("no 112")) 113: debug.str(string("no 113")) 114: debug.str(string("no 114")) 115: debug.str(string("no 115")) 116: debug.str(string("no 116")) 117: debug.str(string("no 117")) 118: debug.str(string("no 118")) 119: debug.str(string("no 119")) 120: debug.str(string("no 120")) 121: debug.str(string("no 121")) 122: debug.str(string("no 122")) 123: debug.str(string("no 123")) 124: debug.str(string("no 124")) 125: debug.str(string("no 125")) 126: debug.str(string("no 126")) 127: debug.str(string("no 127")) 128: debug.str(string("no 128")) other: case i 129: debug.str(string("no 129")) 130: debug.str(string("no 130")) 131: debug.str(string("no 131")) 132: debug.str(string("no 132")) 133: debug.str(string("no 133")) 134: debug.str(string("no 134")) 135: debug.str(string("no 135")) 136: debug.str(string("no 136")) 137: debug.str(string("no 137")) 138: debug.str(string("no 138")) 139: debug.str(string("no 139")) 140: debug.str(string("no 140")) 141: debug.str(string("no 141")) 142: debug.str(string("no 142")) 143: debug.str(string("no 143")) 144: debug.str(string("no 144")) 145: debug.str(string("no 145")) 146: debug.str(string("no 146")) 147: debug.str(string("no 147")) 148: debug.str(string("no 148")) 149: debug.str(string("no 149")) 150: debug.str(string("no 150")) 151: debug.str(string("no 151")) 152: debug.str(string("no 152")) 153: debug.str(string("no 153")) 154: debug.str(string("no 154")) 155: debug.str(string("no 155")) 156: debug.str(string("no 156")) 157: debug.str(string("no 157")) 158: debug.str(string("no 158")) 159: debug.str(string("no 159")) 160: debug.str(string("no 160")) 161: debug.str(string("no 161")) 162: debug.str(string("no 162")) 163: debug.str(string("no 163")) 164: debug.str(string("no 164")) 165: debug.str(string("no 165")) 166: debug.str(string("no 166")) 167: debug.str(string("no 167")) 168: debug.str(string("no 168")) 169: debug.str(string("no 169")) 170: debug.str(string("no 170")) 171: debug.str(string("no 171")) 172: debug.str(string("no 172")) 173: debug.str(string("no 173")) 174: debug.str(string("no 174")) 175: debug.str(string("no 175")) 176: debug.str(string("no 176")) 177: debug.str(string("no 177")) 178: debug.str(string("no 178")) 179: debug.str(string("no 179")) 180: debug.str(string("no 180")) 181: debug.str(string("no 181")) 182: debug.str(string("no 182")) 183: debug.str(string("no 183")) 184: debug.str(string("no 184")) 185: debug.str(string("no 185")) 186: debug.str(string("no 186")) 187: debug.str(string("no 187")) 188: debug.str(string("no 188")) 189: debug.str(string("no 189")) 190: debug.str(string("no 190")) 191: debug.str(string("no 191")) 192: debug.str(string("no 192")) 'if you would do another "other" 'here you would get an errormessage blocknest stackoverflow 'other: debug.str(string("no 191")) 'case i '191: debug.str(string("no 191")) 'but why not using several case statements after each other like here 'or if you need only different values to use the command "lookup" case i 193: debug.str(string("no 193")) 194: debug.str(string("no 194")) 195: debug.str(string("no 195")) 196: debug.str(string("no 196")) 197: debug.str(string("no 197")) 198: debug.str(string("no 198")) 199: debug.str(string("no 199")) 200: debug.str(string("no 200")) 201: debug.str(string("no 201")) 202: debug.str(string("no 202")) 203: debug.str(string("no 203")) 204: debug.str(string("no 204")) 205: debug.str(string("no 205")) 206: debug.str(string("no 206")) 207: debug.str(string("no 207")) 208: debug.str(string("no 208")) 209: debug.str(string("no 209")) 210: debug.str(string("no 210")) 211: debug.str(string("no 211")) 212: debug.str(string("no 212")) 213: debug.str(string("no 213")) 214: debug.str(string("no 214")) 215: debug.str(string("no 215")) 216: debug.str(string("no 216")) 217: debug.str(string("no 217")) 218: debug.str(string("no 218")) 219: debug.str(string("no 219")) 220: debug.str(string("no 220")) 221: debug.str(string("no 221")) 222: debug.str(string("no 222")) 223: debug.str(string("no 223")) 224: debug.str(string("no 224")) 225: debug.str(string("no 225")) 226: debug.str(string("no 226")) 227: debug.str(string("no 227")) 228: debug.str(string("no 228")) 229: debug.str(string("no 229")) 230: debug.str(string("no 230")) 231: debug.str(string("no 231")) 232: debug.str(string("no 232")) 233: debug.str(string("no 233")) 234: debug.str(string("no 234")) 235: debug.str(string("no 235")) 236: debug.str(string("no 236")) 237: debug.str(string("no 237")) 238: debug.str(string("no 238")) 239: debug.str(string("no 239")) 240: debug.str(string("no 240")) 241: debug.str(string("no 241")) 242: debug.str(string("no 242")) 243: debug.str(string("no 243")) 244: debug.str(string("no 244")) 245: debug.str(string("no 245")) 246: debug.str(string("no 246")) 247: debug.str(string("no 247")) 248: debug.str(string("no 248")) 249: debug.str(string("no 249")) 250: debug.str(string("no 250")) 251: debug.str(string("no 251")) 252: debug.str(string("no 252")) 253: debug.str(string("no 253")) 254: debug.str(string("no 254")) 255: debug.str(string("no 255")) 256: debug.str(string("no 255")) 'another limit are 256 string-constants (0-255) 'debug.str(string("no 257")) 'error too many string constantsbest regards
Stefan
Post Edited (StefanL38) : 4/12/2009 4:25:35 PM GMT
