how to restrict a "do loop" to run for a several certain interval or collect th
I·am doing a project and need to meaure the average value of·a·quantity in·given period(say , 1min) using BS2.
Instead·using the command "count", i collect the quantity with "button".
But i can't collect the time used
I would like to ask if there has another command related to the time used, or retricted the time of a do-loop
Alternatively, it would be grateful if there has another path to collect the rate.
Post Edited (jason0324) : 4/11/2009 6:44:08 AM GMT
You can aproach this result by knoing the time of each iteraction but if you have a timed command inside this loop, like PULSIN the thing is just impredictible.
maybe there´s a better way to do that .. what kind of event are you trying to get the frequency ?
Amaral
