Tilt sensing using accelerometer
Hi, im new here and im stuck with accelerometers... i have been reading this...
http://www.freescale.com/files/sensors/doc/app_note/AN3107.pdf
on page 3 i get confused. An accelerometer is most sensitive when it is perpendicular to gravity (i.e. 0 degree) and least sensitive at 90 degree. It explains that the resolution at 0 degree when using an 8bit ADC is 0.92 degree. I understand how to calcuate this but then i get stuck with the resolution at 90degree. Im guessing that the sensitivity in the equation to calculate 90 degree resolution is not 800mv/g as it was for the 0 degree calculation?
Please can somebody help me calculate the 6.51 degree they have calculated as ive spent over two days trying several things!! Also im using adxl203 and it has 17.5mg sensitivity upto 45 then 12.2mg sensitivity above 45 to 90. What does this mean in terms of voltage/degree? i get 2.5V as offset and 3.5V at 90 degrees. How do i calculate the max resolution at 90 degree?
I would appreciate any response.
Many thanks in advance!!
You can use a single axis accelerometer to accurately measure tilt when the angle is than +/-60 degrees. The best results occur at an angle below +/-30 degrees, resulting in an error of less than 1%. Since the tilt calculation is derived from a sin (angle) calculation, there is minimal change for an angle greater than +/-60 degrees, resulting in an inability to measure tilt at +/-90 degrees with a single axis accelerometer.
Parallax provides documentation here for the Memsic 2125 accelerometer that describes a technique to measure tilt and acceleration. Read the datasheet for the Analog Devices part and the two application notes and you should have the information required measure tilt at +/-90 degrees with a dual axis accelerometer.
························ Craig Eid
··········· Triad Research and Development
Electical Engineering Design and Consulting Services
··················· www.TriadRD.com
Post Edited (Craig Eid) : 4/10/2009 7:05:01 AM GMT
Thank you!
Jessica
Jessica Uelmen
Education Department
http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf
MAny thanks in advance again and thank you a]gain for your response!!!
You are correct that the sensitivity at 90 degrees in the referenced equation is not 800mv/g; the sensitivity·is 0mv/g. The data you are referencing is a plot of Sin(X) vs X [noparse][[/noparse]degrees].· As noted previously, there is minimal change for an angle greater than 60 degrees which significantly reduces the sensitivity.·Please review the tabular results in the attachment for·an understanding of the variation of Sin(X) vs X·over the range of +/- 90 degrees.
