Strange Pin Problem
Hello everyone, I recently built my second protoboard setup, and have been having problems with the parallax GPS receiver. Instead of 1K current limiting resistors in series on the signal lines to the GPS and other 5v devices (first revision), there are 2.2K (current revision). Everything works correctly with the new 2.2k resistors, except for the GPS. After trying out a second identical GPS receiver, I tried running the same code on both of my protoboards. The 1k one works fine, the 2.2k does not. In this thread (http://forums.parallax.com/forums/default.aspx?f=25&m=124837) Chip Gracey said on a bi-directional signal line, a series resistor should work. Since the GPS module is supposedly TTL compliant (threshold voltage: 1.5v), I am very confused
. It seems like I could either a) have a faulty board b) have messed something up during soldering or c) the 2.2K resistor is causing a serial communication problem.
Any thoughts? Thanks in advance.
Edit: Forgot to mention that the GPS is able to get a fix on satellites, suggesting that the power connections are fine.
Post Edited (ReiserificK) : 4/9/2009 9:47:25 PM GMT
. It seems like I could either a) have a faulty board b) have messed something up during soldering or c) the 2.2K resistor is causing a serial communication problem.Any thoughts? Thanks in advance.
1986 Chevy EL Camino·· No prop yet
1984 Suzukie GS1100GK No prop yet
The obvious thing to try is to reprogram the GPS's SX for a CMOS input on the communication pin — either that, or replace the 4.7K pullup on the GPS board with a 10K resistor.
I changed the 2.2k resistor to a 1k and it works now. Thanks for the advice everyone.
