Is 3.3V enough for the VGA sense pin? (pin 9)
Bill Henning
I'm wondering if I don't need a 5V rail on a prototype that otherwise does not need 5V...
Does anyone know?
Bill
www.mikronauts.com - a new blog about microcontrollers
Does anyone know?
Bill
The 5V regulator does share some of the power reduction/dissipation on the way to 3v, but of course you could always use a lower input voltage providing you dont require the 5V.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
This is an excellent question. Unfortunately, I fear the answer may be monitor-dependent. It will depend in large part on which logic family is used to input the sense line. In the case of 74LS and 74HCT logic, no problem. OTOH, 74HC logic could be a problem, since its high input threshold can be as much as 3.5V (but almost never is). On the whole, you probably won't encounter any difficulties at 3.3V.
I have one keyboard that seems to run ok on 3.3V only but more that do not, I have yet to find a mouse that was happy.
The PCB I'm working on does not have a keyboard or mouse, and uses all 3.3V logic, and I wanted to save the 7805 and +5 rail if possible - looks like its pretty safe!
I may put in an optional input that goes to pin9 to feed it 5v if needed (or jumper to 3.3v) in case of non-working monitor.
