Can I multiplex the signals to keypad and LCD?
HI, I'm trying to not buy a serial LCD as I've got a good Parallel one.
But I also needing to hook up a keypad and a temp sensor and relay
for a reflow oven I want to build. Any Ideas?
maybe a shift register? Thanks for any help.
www.sparkfun.com/commerce/product_info.php?products_id=258
I realize you are trying to cut down on I/O Pins?
If you are, you can try this:
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol1/col/nv43.pdf
If you don't already have something for the keypad, this will help out as well.
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol1/col/nv22.pdf
The complimetary I/O pins article was written in 1998 so that IC might not be availible anymore.
If you know how you could program an SX to convert parallel to serial for the keypad and for the LCD.
When you get your reflow oven done, post it on the Compleated Projects page. I would love to see it.
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
http://www.parallax.com/dl/appnt/stamps/bs1Appnotes.pdf
http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol4/col/nv97.pdf
Chris Savage
Parallax Engineering
