Where to find 100PSI submersible connector?
I need to go with my 4-20mA current loop sensor about 200 ft under water. For that I tried to find a small (dia = 0.5 inch max) circular 3-pin connector that can·withstand that kind of pressure (say 100 PSI max). So far no such luck - and I did tried indeed
Please reply in case you know who makes such connectors...
Thnx
Thnx
Also, try Googling IP68 cordset. IP68 is a submersible rating and needs to come with a maximum depth attached to the spec.
Post Edited (Phil Pilgrim (PhiPi)) : 4/10/2009 3:39:21 AM GMT
John
