Prop to BS2 Debug
I have been trying to make the prop demo board·talk to my computer through the debug terminal. At first I tried doing it straight through the USB. This Did Not Work. All·I ever got it to display was a·rectangle block. I then tried sending the letter "a" followed by a·decimal 1, through the basic stamp. It didn't do·much for a while, but after i left it, it displayed a "p". Can someone tell me how to·display text on the Basic Stamp Editor Debug Terminal, preferrably through the USB port on the demo board?·
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
START:·
>Saving Data. . . .
>Signing OFF
Andy Lindsay
Education Department
please atach your code with the attachment-manager of the forumsoftware
without the code it is really hard to say where the bug is
best regards
Stefan
I tried it using the basic stamp debug terminal, and it displayed strange characters, But at least it did somthing!
START:·
>Saving Data. . . .
>Signing OFF
Also, the Parallax Serial Terminal is the Debug Terminal, but adjusted for use with the Propeller. Download it and try it with the application. Follow the instructions in the post step-by-step, and it should work well for you.
Andy Lindsay
could you please "process your Data" and attach your code to a posting
best regards
Stefan
START:·
>Saving Data. . . .
>Signing OFF
My code isn't much. Just trying to test sending the letter 'a' somthing like:
OBJ
ser : "SimpleDebug"
Pub Serial
ser.start(9600)
ser.putc("a")
START:·
>Saving Data. . . .
>Signing OFF
ha got you (maybe) - as you refused to post your COMPLETE code
did you include the following lines in your code ?
if NOT you might be working in a clockmode that isn't accurate enough for serial transmission
a small program does NOT mean everything is working in every case
(it might be too small)
best regards
Stefan
START:·
>Saving Data. . . .
>Signing OFF
