Need help please
                    I am currently working with the GPS sensor right now. I have it up and running and able to retrieve information from the satelites.
I need a way to take that data and store it into the stamp i am using.
I am thinking about using a DATA program, but I am open to other ideas.
- Stephen
What Franklin suggested is very reasonable for storing more data than will fit in the Stamp's memory or when you need to get the data out of the Stamp easily for analysis elsewhere. Maybe that is one very good solution to your problem.
You need to say more about what you're trying to do. For example, what GPS data are you interested in keeping? How often do you need to store it? How are you going to use the data?
