Is it a benifit to use a mosfet driver with a logic style mosfet?
Do Logic style (IRL)·Mosfets··need or benifit from a mosfet driver to open the gate fast, like a·Non-Logic (IRF)Mosfet.
Thank you
Bill
Thank you
Bill
Can an SX48·@20 - 50mhz drive a logic mosfet to 4mhz or above (I just picked that #, it has no significance) without a driver, if a mosfet has a certain charactristic? Perhaps a certain range of input or output capacitance?
The other thing to consider, is the logic device itself. A propeller can supply a fair amount of current, but if you have a mosfet with fairly high capacitance, you might blow out an IO pin due to the large inrush current.
So, yes, a mosfet driver is generally recommended unless you are simply "powering on" a device with the mosfet, i.e. very infrequent switching. Reason one, preventing the mosfet from getting hot, and reason two - protecting the logic device that is supplying the signal.
As for the SX, I'm not TOO familiar with the chips, but 4mHz is pretty high even for my 9A driver! You should DEFINATELY use a high current driver for those kinds of frequencies. If I may ask, what are you making? I've always wanted to make an inductive heater with high freq's like that... [noparse]:)[/noparse]
Like many people, I have about a half dozen projects going all at one time, lol. Many of them are inductive projects like Ignition systems, DC-DC converters and H bridge motor control. There have been a few articles in Nuts n Volts in the last year, one of them was for adding a micro-controller into a slot car. In that article they mentioned the motors made noise (and noise was bad) above 1Mhz and below 4Mhz when the controllers were operating at those frequencies.
Somebody (on this forum), possibly Mike Green, suggested adding a transistor as a bridge between a microcontrollers and the source voltage as an alternative. I could see where that may help turn on a mosfet but would it work as well to shut the mosfet off. Or does a mosfet driver work the best for on and off?
Post Edited (Capt. Quirk) : 4/5/2009 2:23:56 AM GMT
I have no clue why anyone in their right mind would be running a DC motor at >100kHz, let alone, 1 Mhz! That's in the RF range, and you're right - that WOULD cause a bunch of noise. Not just in the circuit, but totally external devices absorbing RF energy.
If you want isolation between the motor and your circuitry, I'd suggest using an ISO721. It's an isolator that totally isolates circuits. You can have completely different supplies and grounds with this thing, meaning your uC can be the input with the 5V supply and digital ground, and the output would be on the other side(isolated) with it's own voltage and ground. The chip works up to 150megabits/second. PROBABLY fast enough... Oh, and you can get a few free as samples from TI.com to try out. Yes, I rape and pillage their samples department when I am trying out something new... But I do eventually buy some parts when my design is finished. Just go easy on them. [noparse]:)[/noparse]
