PCMCIA to PCI Adaptor
I've searched all over the net to try to find an adaptor that can give a laptop PCI functionality, searching with google just brings up PCI to PCMCIA, I need it the other way round,·does such an adaptor exist?
Basically I need to connect an ADC/DAC PCI card to my laptop and presumed that a cardbus connection might exist as i cant imagine USB to be·capable enough to drive a PCI card not really understanding protocols and connections·involved, the card itself though is a breeze to use and is easy to control with Qbasic, just wondering now if Windows XP will support Qbasic? Oh well i'll cross that bridge when I come to it.
Anyway thought i'd ask the clever people on this forum if they know of such a thing and if it is possible?
The laptop slot is Type II
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
check wlan parts or google wireless parts suppliers. Mikrotik comes to mind.
Old Man I think those are the wrong way round to what im hoping for ie i want a type II card to plug into the Laptop to give me a PCI slot.
Thanks for the replys guys
You could attach a Labjack to the USB2 port - check here www.labjack.com/results.php?category=2
http://sewelldirect.com/magmacb1h.asp
Duffer
Ugha I cant see a slot on the exterior and i'm a bit worried about opening up the laptop
Duffer thats what i need but as you said the price has put me off, it looks like I may have to resort to putting it in an old desktop which wasnt the portable machine I was hoping for.
Lack of funds may make the option of building a small system prohibitive at the moment.
But thanks for the ideas, much appreciated.
If you have the built-in wireless option, then your laptop supports a Mini-PCI card internally. This is bad... as it will take quite a bit of work to try and get into it. This will:
A: void your warrenty
B: take a good bit of skill at disassembling the entire laptop
C: have a good chance of damaging the system if you make a mistake.
As far as adapters, I've found some info about future PCIe cards for PCMCIA but I couldn't find any existing products.
Could you perhaps use a different kind of device for what your trying to do? Maybe you could tell us what your end goal is and we can come up with something else that'll
work and is cheap?
Maybe someone reading this post has a better memory than I do and can help.
The only other thing I can think of doing is to repackage an old PC into as small a package as possible, or find an older laptop that has a mini PCI connector used to connect to a docking station.
The card was expensive when bought £400+ if I remember so im loathe to just throw it away, besides that I spent so long writing and tweaking the software for it to get it just right and having spent time learning how to use the card I wouldn't want to spend more time learning that could be better spent building.
Thanks for your research into my laptop as I think I would have got lost in the understanding of what the internals of it would or would not support
Kwinn The route of buying an old cheap laptop with docking station may be the solution and I will take a look on ebay
Again thanks very much guys for your time and help.
Kwinn
Post Edited (skylight) : 4/5/2009 6:59:43 PM GMT
