Power from Green LEDs?
Oldbitcollector (Jeff)
For some reason I was hooking various LEDs to my meter late the other night,
(don't ask, it's a sleep deprivation activity for hardware geeks.)
and I noticed that I was getting current from LEDs, a rather nice amount from
green LEDs, when I held them under my shop light.
I'm starting to wonder if I were to collect a few more, maybe I could use them
in place of small solar cells? They certainly are smaller. I doubt I've made any
new discovery here, but does anyone understand why this is working this way,
or even more why/why not this is/isn't a practical way to generate a small amount
of electricity?
OBC
New to the Propeller?
of electricity?
OBC
As to producing enough current to power anything I doubt that very much. If you connect a current meter you will be fortunate to read 10's of microamps but more than likely only 1 microamp or so even under very bright light. Of course in so doing your terminal voltage is now almost zero. Don't draw any current and you will read around 1.5V, but not both together. I think a lemon makes a better power source, and four lemons should be able to power a Propeller. But if the lemons aren't fresh then the brownout detector operates
@SRLM: If leds were plants you might be right.
*Peter*
Tracy Allen
www.emesystems.com
You won't solve the energy crisis with LED's but you can have some fun experimenting with different parameters using·a low input current op amp. You can compare the change in LED current as a function of·LED color (red, green, and blue), wavelength (red, green·and blue filters) and luminous intensity (standard and high output LED's).
Have fun!
························ Craig Eid
··········· Triad Research and Development
Electical Engineering Design and Consulting Services
··················· www.TriadRD.com
If you get your LEDs right you can even roll your own optocoupler, one you can actually see working. (Perhaps something you can include in your book)
Put two high efficiency narrow angle 5mm leds directly facing each other. The voltage transfer ratio is surprisingly good but current ratio very poor (hence not much power). But good enough for driving CMOS inputs etc.
If you need more voltage you can use two pairs - two transmitters in parallel, and two receivers connected in series to give ~ 3-4 volts.
I believe there is also some kind of wavelength shift - so you might get best results emitting Yellow but Receiving on an Orange LED, or vice versa (cannot remember which way it shifts)
If you want to see a commercial implementation check out the PVI by IRF
www.irf.com/technical-info/appnotes/an-1017.pdf
tubular
