No data from gps
Hello,
I have a parallax GPS unit. Recently, I used it in a project and it worked fine. However, now I cannot get any serial signal from it. I have even reverted back to the trial program with no results and tried both floating /RAW and pulling it low. The light on the gps flashes and it gets a fix, but outputs no data.
Any help would be greatly appreciated!
- Stephen
························ Craig Eid
··········· Triad Research and Development
Electical Engineering Design and Consulting Services
··················· www.TriadRD.com
The 5 volt power supply (VDD) on the BOE is derived·from an LM2940, conservatively rated at 1 Amp. If you are powering the GPS module from VDD on the BOE and the remainder of your circuit functions properly, you can deduce that the power supply is not your problem.
