Ing. coil driver and the SX/28
Helllo All
I need a good driver ( transistor, FET,MOSFET etc.) To drive and·Ing. coil from the output of a SX/28.
Their are so many (drivers) to choose from, So I'm not sure witch would be the better choice with the 5volt TTL
level output from the SX/28?
I have a working code I wrote for this APP. using LEDs. It works fine.
Now All I need is a way to fire the coils and deal with the BEMF.
Any help would be Appreciated
_______________$WMc%_____________
The Truth is out there············································ BoogerWoods, FL. USA
First·question that comes to mind,· What sort of current does the coil draw? Do you have a spec or can you measure the current that it draws?
-Paul
Thanks for the BIP373, This sounds promising. I did a search for the BIP373 on Mouser's web site and didn't come up with anything. Do You have a source for this device and where to get a DATA sheet for it?
I haven't selected any coils yet. I figured I would wait until I found a good Ing.coil driver for the SX28, and match the coils to it for My Ing. program.
I'll need a DATA sheet to setup the device properly and to insure that no EMF makes its way back the SX28!
___Thanks in Advance______$WMc%_______
Post Edited ($WMc%) : 4/5/2009 2:00:33 AM GMT
www.megamanual.com/ms2/bip373.htm
-Paul
It appears that the driver could be driven with a simple npn transister. The current for the Bosh device is ok for the SX unless you are dirving a lot of other outputs. A simple transister driver would suffice or if you want to really isolate the circuit, us an opto isolator. If you suse the Radio Shack Infared photo transistor and led package, you will have to use a transistor to drive the led as the IR led wants 100 MA! I am using one in a motor drive circuit where I had some groundloop problems between two power supplies. I am using the photo transistor to directly drive a Mosfet which is my motor driver. I belive the photo transistor would directly drive the bosh/
Regards
RS_Jim
I liked the BIP373 but at $8.00 ea. WOO ,and I have found only one source that carries them.
This device looks more like an injector driver with its MAX output at the start of the pulse and then a reduced current for the rest of the pulse duration?
I like Your opto-iso/MOSFET setup.
What are You using to protect the MOSFET's from "flyback-voltage" from the motor windings in Your motor controller? . I feel this will be close to what I would get using an ING. coil, instead of a motor?·
Should I use something more than a diode and cap with the MOSFET?
_________________________$WMc%_____
Post Edited ($WMc%) : 4/19/2009 2:11:57 AM GMT
Thanks for the info,The link, and the possible down side to using other IGBTs.
The BIP373 sounds like the best choice here,But I need 4 of them for this project, My 1939 Ford-Ferguson tractor. A V8 motor would really get expensive,I still need coils, etc.
I'll checkout the offerings from Fairchild and compare options.
____Many thanks______$WMc%_______
This is getting better and better!
I'll check this out as well.
___Thanks again_______$WMc%_____
Thanks again for the links to coil drivers.
·I looked these up, But I'm having a hard time reading the data sheets."never used IGBTs before"
I'm not sure from the data sheet, How much current the gate needs to turn-on fully, or the voltage needed?
I want to make sure I don't overload and I/O pin on the SX/28.
Any clarification on the IGBT lingo would be Great!
I have included the Fairchild data sheets below
__I Like the price @ $2.50 or <___________$WMc%___
I have experience of this type of design with triggering of high power flash tubes for laser pumping.
I used a fast maxim max628 MOSFET driver feeding the gate of a 900V MOSFET with the drain connected to the induction coil primary.
The max628 can provide upto 2A drive to the MOSFET for fast and efficient switching.
Hope this helps you.
Regards
devidebyzero
After I have looked through all the info. I still don't no the trigger current on the IGBTs
I dont understand the lingo in the DATA SHEETs for the IGBTs
I don't want to exceed the (PIN) current rating of the SX/28
How do I fig. the current needed to turn on A IGBT. ????
-Paul
This is what I was looking for!!!
Many Thanks!!!!!
