Sx Serial Comms problem
Hi Guys
Im having trouble getting serial comms to work, I know it's my code thats messing it up.
I am sending out a 3 digit number from a propeller board, I know this works as I have an arduino that can receive the 3 bytes that make up the number.
However i cannot get this code to work on the SX, all I want to start with as a test, is for it to receive a number, and if that number matches 001, switch on pin 1, 002, switch on pin 2 etc.
But I think my problem is that the SX is only receiving one byte, and not the 3 bytes, ive never been any good with the SX so would appreciate some help.
Here is my code so far:
DEVICE sx48, OSC4MHZ
IRC_CAL IRC_SLOW
FREQ 4_000_000
PROGRAM Start
sData var Byte
leds var byte
Start:
'OUTPUT RA.2
'OUTPUT RA.3
Main:
DO
SERIN RA.1, N9600, sData
'001 = RA.2
'002 = RA.3
'LEDs = sData
if sdata = 001 then
toggle RA.2
endif
LOOP
DJH
IRC_CAL IRC_SLOW
FREQ 4_000_000
PROGRAM Start
sData var Byte
leds var byte
Start:
'OUTPUT RA.2
'OUTPUT RA.3
Main:
DO
'001 = RA.2
'002 = RA.3
'LEDs = sData
if sdata = 001 then
toggle RA.2
endif
LOOP
DJH
With regards the crystal, is that definatley needed for low speed comms?
What about my code only wanting to receive 1 byte?
DJH
You only have one SERIN statement, and that works with bytes. If you search the forums you'll find several examples of SERIN wrapped in a function called RX_BYTE that allows you to call it multiple times without consuming code space.
I did find those posts, but I could not figure out how it was working, or how to get the received data into a variable with a format that I wanted.
DJH
For example: you say you're sending out a 3-digit number from the Propeller. Is that three ASCII characters? (e.g., "001") -- these are important details.
If you are in fact sending ASCII characters these routines will give you an idea of how to put SERIN into a function and how to receive a value as an string -- up to three characters (any non-digit character will terminate the input).
I had replied...But then Jon said exactly the same thing before I did. So I deleted the post.
You MIGHT get away with using the internal oscillator and "IRC_CAL IRC_4MHZ" but it will be iffy. The slower the baud rate the better luck you will have.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
DJH
I hate to be a spoiler in all of this, but I use the internal oscillator at 4 MHz for serial comms at 9600 frequently, and find it totally reliable provided one is able and prepared to "tune" the software timing to suit.
Additionally, the stability with temperature is adequate.
I normally run things at 50 MHz with a resonator, but for low cost and battery apps the internal 4Mhz works just peachy.
All that said, for critical applications I would go to a resonator, but I have some applications where there just is no room for the leaded part.
Cheers,
Peter (pjv)
I have the TX line pulled low on the propeller board, but it goes direct to the RX pin on the SX board and the 2 boards share the same ground.
DEVICE sx48, OSCXT2
IRC_CAL IRC_SLOW
FREQ 4_000_000
PROGRAM Start
sData var Byte
leds var byte
tmpB1 var Byte
tmpB2 var Byte
tmpB3 var Byte
rxDigit VAR tmpB1
rxIdx VAR tmpB2
rxResult VAR tmpB3
RX_BYTE SUB 0
RX_DEC3 SUB 0
Start:
Main:
RX_Byte
if rxResult = 001 then led
led:
output ra.2
Pause 3000
goto main
FUNC RX_BYTE
SERIN RA.1, N9600, __PARAM1
ENDFUNC
FUNC RX_DEC3
rxResult = 0 ' clear result
FOR rxIdx = 0 TO 2 ' allow up to 3 digits
rxDigit = RX_BYTE ' get a digit from stream
IF rxDigit < "0" THEN EXIT ' abort on non-digit
IF rxDigit > "9" THEN EXIT
rxDigit = rxDigit - "0" ' convert from ASCII
rxResult = rxResult * 10 ' update result
rxResult = rxResult + rxDigit ' add new digit to result
NEXT
RETURN rxResult
ENDFUNC
http://forums.parallax.com/forums/default.aspx?f=15&m=258522&g=258661
JonnyMac has published some excellent examples using the SX where it uses a protocol like this to send data. I believe Parallax has many on their site as a PDF download. I would try using those to start with and build from that. The ISR based serial receive code is nice since it can watch for stuff coming down the serial line in the background and you won't miss anything.
You mention the two chips are sharing a common ground. Are you running both chips at 3.3V or is the SX running at 5V?
Prop is on 3.3V and the SX must be on 5V come to think of it as im using the project boards.
It wasn't a problem with an arduino tho but that may have been luck.
I am doing it this way as the Prop will be using the serial TX line as a sort of bus, I will have SX boards, Picaxe boards etc listenning in until they get a command that is meant for them.
regards
DJH
I can't thank you enough for spending the time writing that out.
As soon as I get back I will give it a go.
DJH
Ok
I went to compile it, I changed the T9600 to N9600 as my prop does serial inverted (pulled low), also changed the chip to SX48. It failed to compile as the command that said "PUTBIT" came back as not being a command, I have never used the "PUT" command so I tried it as "PUT BIT" but still no compile, so i took out the bit and it compiled ok, but im presuming that breaks it now?
Also I added in a line to try and make RA.2 high when the value 001 is recived (just as a test).
Also I have a 3 pin resonator in X2 on the board, does that mean the osc setting needs to change?
I have re-attatched the file so you can see my changes, and possibly where i broke it.
Am I correct in thinking that it would make all of portC go low is "999" is received?
Im trying to learn from your code.
Thanks Again
DJH
What should the OSC be set to, to use the X2 port on the dev board?
DJH
Ok, no luck, I have tried it a few different ways, so it must be my circuit?, so a checklist:
RB.0 is being used as the RX on the SX board.
Gnd on both boards is connected.
I am using N9600 on the prop
I am using N9600 as the baud on the SX, but I don't know if the hardware is, as if I put a multimeter between GND and the RX pin on the SX, I get 1.48V, when the pro Xmits it drops down to 1.32 for less than a second (obviosuly not accurate). If I disconnect the SX board, the voltage on the props TX pin is 0v, and rises to 0.3V when xmitting.
Is that right? The only circuitry I have, is a 4.7k Pull-Down resistor on the prop board for the TX lead. no components on the SX side.
Should I set the pin to NOPULLUP on the SX side as im using the serial inverted?
Sorry to be a pain, must be getting on your nerves by now
DJH
One of the simple facts that you seem to be ignoring is that the SX has a TTL threshold of 1.4 volts; this is why nothing is getting through (based on your measurements). A better solution, in my opinion, is to use Open-True (OT) mode with a pull-up on the line between the Propeller and the SX. The Propeller is 5v tolerant and the pull-up (4.7K to 5v) limits the current through the TX pin on the Propeller when it makes that pin an output-low (for start and zero bits). Using the pull-up keeps the signal on the SX side legal.
I wrote a simple program for a Propeller demo board that spits out bytes in OT mode; on the receiving end is an SX28 in a PDB with a pull-up on its RX pin (to 5v) and the port C bits connected to LEDs. It works.
Do I not also need a pullup to 3.3v on the prop side?
As thats what sets it's mode (True or inverted)
Right now, I have changed it so there is a pullup on the prop to 3.3v (4.7K) and that goes straight into the SX RA.0 pin, the pin now reads around 3.3v and drops to 2.26V when xmitting (not accurate).
Question is, is it dropping below 1.4V so fast that the multimeter does not register? Or do I still have the wrong voltages?
If I pull it up to 5v, I presume that I don't pull it up to 3.3v on the prop side?
Daniel
I have tried it with just the 4.7k pullup to 5v on the SX side, and the voltages seem the same, around 3.6V dropping to 2.8 when xmitting.
I had to change the code a little to test it, could you have a quick look for anything glaringly obvious?
I changed it so that it puts 2 leds high when it received 999 via serial
DJH
I haven't seen any mention of how you have the LED's connected. Are they connected to 5V with a current limiting resistor to each SX pin and setup to light when pulled low? Have you ever seen the LED's change state and light if you make a tiny program to flash the LED's?
Before making any changes to Jon's code why not just temporally connect some LED's to port C on your SX chip to exactly replicate what Jon has working. If that works then build on that. If not then you have some other connection problem and more tweaks to the code will just waste time looking for a problem that may be somewhere else.
I know the prop xmits, as my arduino board receives the transmission fine.
I have been checking PortC with a mulitmeter, but trying an led will not be a problem
Yes I the leds on PortB with 180ohm resisitors
DJH
